Yes or no?
  • Yes or no?
    will Vray RT GPU final version support these features?
    please answer YES/NO/TO BE IMPLEMENTED/IMPOSSIBLE TO IMPLEMENT
    support for production render:
    32 bit exr/hdr save:
    alpha channel:
    support for caustics maps:
    support for translucency:
    anisotropy:
    dispersion:
    Phong, Blinn, Ward:
    Opacity channel:
    normal map:
    VrayHDRI:
    Max procedural textures:
    Falloff, gradients:
    VrayBlend:
    Vray2sidedMtl:
    VrayFastSSS:
    Vraylight exclude/include filter:
    Vraylight affect diffuse/specular/reflections:
    Vraylight Skylight portal:
    Vrayproperties visible in reflection/refractions:
    Vrayproperties Matte object:
    Vray proxy:
    Vray infinite plane:
    GI environment override:
    Ambient occlusion:
    Mixed DR with GPUs and GPUs selectable from the control panel:
    check for missing files:
    Backburner net render:
    Image/pixel aspect:
    support for Multiscatter and/or Forest Pack:
    motion blur:
    particles:
    particles motion blur:
    support fot atmospheric effects:
    support for post effects:
    Best regards
    support for production render: Probably
    32 bit exr/hdr save: (when used as production renderer)
    alpha channel: Yes
    support for caustics maps: No. Caustics are only supported as GI caustics.
    support for translucency: Not at this time.
    anisotropy: Not at this time.
    dispersion: Not at this time.
    Phong, Blinn, Ward: Yes, these are already supported.
    Opacity channel: Yes, this is already supported.
    normal map: Yes, this is already supported.
    VrayHDRI: Yes, this is already supported.
    Max procedural textures: Not at this time.
    Falloff, gradients: Not at this time.
    VrayBlend: Not at this time.
    Vray2sidedMtl: In an update.
    VrayFastSSS: Not at this time.
    Vraylight exclude/include filter: Not at this time.
    Vraylight affect diffuse/specular/reflections: Not at this time.
    Vraylight Skylight portal: Not at this time.
    Vrayproperties visible in reflection/refractions: Yes, these are already supported.
    Vrayproperties Matte object: Not at this time.
    Vray proxy: Not at this time.
    Vray infinite plane: Not at this time.
    GI environment override: Not at this time.
    Ambient occlusion: Not at this time.
    Mixed DR with GPUs and GPUs selectable from the control panel: DR with GPUs is possible; you can select which GPU a given slave is using by running OCLDeviceSelect on the particular machine.
    check for missing files: probably, only when used as a production renderer
    Backburner net render: only when used as a production renderer
    Image/pixel aspect: yes
    support for Multiscatter and/or Forest Pack: No.
    motion blur: In an update.
    particles: Yes, this is already implemented.
    particles motion blur: In an update.
    support fot atmospheric effects: No.
    support for post effects: only when used as a production renderer.
    Note that all of this is subject to change, until the actual release.
      many thanks!
        Heck, what a list. There are actually quite a few things in there that will prevent RT from being particularly useful in our workflow.
        Kind Regards,
        Richard Birket
        http://www.blinkimage.com
          Well, this list is RT GPU. RT can do some of the above.
          What worries me is that I was hoping that RT and RT GPU would converge to the same feature set, so that I could retire RT thinking and always use GPU but that doesn't seem to be the case.
            The list is for the GPU version only. For the CPU version the list is as follows:
            alpha channel: Yes
            support for translucency: In an update.
            anisotropy: Yes, this is already supported.
            dispersion: Probably.
            Max procedural textures: Yes, they are already supported.
            Falloff, gradients: Yes, they are already supported.
            VrayBlend: Yes, it is already supported.
            Vray2sidedMtl: Yes, it is already supported.
            VrayFastSSS: In an update.
            Vraylight exclude/include filter: In an update.
            Vraylight affect diffuse/specular/reflections: In an update.
            Vraylight Skylight portal: Yes, it is already supported.
            Vrayproperties Matte object: Yes, this is already supported.
            Vray proxy: Yes, it is already supported.
            Vray infinite plane: Yes, it is already supported.
            GI environment override: Yes, it is already supported.
            Ambient occlusion: In an update.
            DR: Yes, DR is already supported.
            support fot atmospheric effects: In an update.
              This is not going to be the case for quite some time. I'm sure things will move towards that point, but GPU capabilities are still not there.
                Looks like I'm our of GPU too... and it was looking to be such a amazing year hehe
                EDIT: Heya, I just remember that back in presentation in siggraph if I'm not wrong, we did see vraymtlblend material on experimental mode, multi kernel stuff bla bla bla, why is it not going to be available in final release?
                  Vlado,
                  Very helpful reply to the first post, thank you.
                  I'd like to request that GI Environment override be a priority for implementation, if possible.
                    So RT will support phoenix fd ? That would be great!
                    I just can't seem to trust myself
                    So what chance does that leave, for anyone else?
                    CG Artist
                      It had its own issues and we decided it was not stable enough for release.
