latest builds of V-Ray RT
  • latest builds of V-Ray RT
    which is the latest build of V-Ray RT?
    i'm on 1.90.01 and it only works with nvidia 258.96 driver
    2.00.02 I believe...
      are you using 260.99 driver?
      if so, any difference in performance?
        no way, 260.99 don't work. black screen.
          ops! i deleted *.clbin file and now it works.
          but...performance is 10% lower
          back to 258.96
            Dunno I'm using latest non-beta drivers from nvidia, All works fine, only RT is pissing mi off here and there when it get bugged/exploited/errored and so on
            Last one is Adaptive progressive rendering (ye I made the name up ), basically its not rendering whole image at once, but flakes of image. It starts at some point in image and then it render like noisy flakes from this point of image... weird....
              You can solve this by decreasing the noise threshold, I think.
                vlado,
                have you experienced the difference in performance moving from 258.96 to 260.99?
                the way nvidia implements opencl instructions seems critical...
                  Originally posted by bear75 View Post
                  vlado,
                  I know that there was an issue with multiple GPUs and the beta versions of V-Ray 2.0; this issue is resolved for the official releases. Other than that, the performance looks very similar, but I have not made exact timings... will try to do that a bit later today.
                    Noise is set to 0.000001
                    Its weird because it happen only in 2 scenes. Will see if it can be reproduced and email u scene. Its quite funny to watch how rt is build up scene hehe
                      performance doesn't look so similar... 15% difference...
                      top 258.96
                      down 260.99
                        How many GPUs are there in your case?
                          2 gtx 460@800 core 2000 memory
                            Ok; will have to test this here as well...
