Hi Peeps,
I have just set up a new system: 2 x 12core magny cours 32 gig ram. I had many headaches getting it to work probably and eventually ended up chucking win7 and going back to trust xp 64 pro. Overall it is much faster then my old quad (q6600) machines except when it comes to rendering proxies.
After a lot of tearing of hair and many facepalm moments I have isolated it to only proxies. When i render a scene with 3 proxy trees - no lights no gi the 24 renders 21seconds and the quad renders 18seconds. The problem is further compounded when i render with opacity mapped leaves where the 24 core is 3:30 and the quad 1:12. The same test with normal geometry trees the 24 core blows the quad away and renders bout 20% of the time it takes the quad.
I have come to realise that it is probably to do with the 24 cores all trying to pull the proxy from the HD at the same time. I tried to make a ram disk but the results where the same (funny). Probably the same issue with the 24 cores trying to access one ram module simultaneously. But this made me wonder ....
If i set up a 5 disk raid 0 array would I see a dramatic increase in performance? Or would i get the same bottleneck?
Any thoughts?
On a side note the ATI 5870's viewport performance is not noticeably better than the 2 year old 8800gtx cards
Any thoughts?
