In the meantime, if memory permits, you can run several independent instances of 3ds Max to render at the same time (also through DR with the same machine).
The guy who built my machine said I if u gonna test form AMD chips i should give you this link to a good tool for analysing your code. I dont know enough about this to know if it will help you but here it is anyways.
Dont know if it helps anyone but I was able to get better performance by running multiple instances of Max with multiple renders. I would put on an additional render and the original render would hardly slow down at all.
Yep, we got about a week ago. From my initial simple tests, I didn't find anything unusual, but they were pretty simple. It would be very helpful if you can get me a scene to test and debug to vlado@chaosgroup.com
