"Building OpenCL trace program..."
  • "Building OpenCL trace program..."
    Hi there,
    We are starting to using Vray RT 2 and we are stock on the line
    It's working on our quadro FX 3500 but it doesn't work on the New quadro 4000 that we have. The drivers are 267.66.
    We have allso try to find the *.clbin but didn't had any luck to find it, even on the computers with the quadro FX 3500.
    We did that :
    Open Windows explorer, type %temp% as the folder name and look for the .clbin file there.
    We are on a domaine, may be is it somewhere else?
    And another question : the fog color and multiplier in vraymtl is not working ? It's so obvious for creating glass...
    3LP Team
    just a screen grab to see the problem...
Name:	14-04-2011 6-49-43 PM.jpg
    Absorption (fog) for refractive materials;
    http://www.spot3d.com/vray/help/rt10...d_features.htm
    doesn't work on gpu on the machines with the Quadro FX 3500
    Any ideas ?
    sorry about all those rt problems, we try to be updated
    3LP Team
      No one has any idea to make things work?
      3LP Team
        Yep, there is a bug with the fog color in the CPU version - will be fixed in the next service pack at the end of this month.
          ok great,
          and concerning the "Building OpenCL trace program..." ?
          Is there a way to make it work on quadro 4000? And do you know where I could find the *.clbin file to try to delete it and solve the problem ?
          Stan
          3LP Team
            ""We are starting to using Vray RT 2 and we are stock on the line
            i have the same problem when switching to gpu .. on win7 , maya 2012 , gforce 480 with latest cuda driver
              It will be stuck there for a while - could several minutes (up to 5 on my machine) - the first time you run it. You just have to wait it out (and pray that nVidia optimize their drivers in the future )
                we finely founded the problem that make opencl haching!
                it's the fact of having "sub-pixel mapping" enable...
                I thought that the error saying that it was a feature not supported for the moment was like the no decay or something else. but that it would not break RT.
                So now that we know that, it works every time when we disable the subpixel mapping.
                although we have a lot of time RT that crash when we start it, saying that the scene is out of memory. we have to close everything and start again and it work.
                any ideas for that as well? and it's definitly not a memory issue because the card has 2Go memory and for the times where it works, evga precision tool shows only 350 Mo used...
                3LP Team
                  It should not be breaking the RT; will make a note to look into it.
                  I'm not sure about that one. Can you get me a scene where we can reproduce this to vlado@chaosgroup.com ?
