Vray GPU Crash :) - cpu n gpu envi profile code?
  • Vray GPU Crash :) - cpu n gpu envi profile code?
    Heya
    So its been a long time since I used RT GPU - like 6 months or so...
    I've run in to some problems >
    Any idea whats wrong ?
    I run 270.33 drivers - I've restarted - initialized GPU and my GPU just crash...
    From other side how to set up enviromental variable to use both CPU and GPU ? I forgot the code I have to type ;s
    evga sr 2
    24 gb ram
    480 gtx asus
    win7pro x64
    Try deleting the *.clbin file in your temporary Windows folder (type %temp% in a Windows Explorer window to go there).
      Ive deleted entire folder
      It works. o.o
      Edit. Nop it dont work. It goes straight to CPU mode... but no crash - so gotta troubleshot it now. Maybe need restart - i've re added my gtx to devices and same thing happen again - instant crash
      That was fun thanks Vlado ! Gotta add it to my list of tweaks
      Also while I'm at it - how to set up environmental variable to use both cpu and gpu ?
        Well, if all else fails, email me to vlado@chaosgroup.com and I'll get you an updated build that should work better.
        The environment variable is VRAY_OPENCL_MIXED_MODE
          Thanks.
          Will fight with it for a bit longer and see how it goes.
          Are there any more temp files that I could get rid off that could cause some issues ?
            Yep, in %appdata%\nVidia\ComputeCache - you can try deleting these as well.
              Heya
              Nop nothing help- I've try almost anything I could think off.. Either crash or straight to CPU mode ... I'll email you soon.
