casting Vraylight shadow in cuda
  • casting Vraylight shadow in cuda
    Hi Vlado,
    thanks againg for give us the Cuda Option to choose.
    I see that if i create a VrayLight and make it invisible, Cuda engine cast the Shadows of the light ( a rectangular shadow if i create a Plane Vraylight..) while RT-cpu no.
    Will it be fixed in the next release or it's impossible to fix because of cuda?
    Render and Animation - WWW.IMERGO.IT
    Could you make an example image for this, please.
    Also the steps to reproduce the issue.
    Thank you.
    Tashko Zashev | chaos.com
      the example in attachment.
      as you can see Cuda cast the shadow of the vrayLight....RtCpu no.
      PS: to reproduce...create a VrayLight and check invisible.
      regards
        Thanks for the pointer; will try to fix it.
          thanks Vlado.
          ah, .... Before or after playing Diablo III ?
            Hehe, it will take a while; that part of the code is a bit tricky.
              Just ran into this myself...
              -Alan
                ok so this is still not fixed ?!? ive got a big shadow on my wall from an invisible vraylight
                  Should work as expected, can you check again?
                  Peter Matanov
                  Chaos
