Who wants mine 680 4gb one? =D
Nvidia Titan
Its about 53 seconds faster then mine GTX 580. Its good, but I hope a little bit faster for this expensive card.AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
2D | 3D | web | video
jiri.matys@gmail.com
https://gumroad.com/jirimatys
https://www.artstation.com/jiri_matys
https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
https://www.instagram.com/jiri.matys_cgi/
https://www.behance.net/Jiri_Matys
https://cz.linkedin.com/in/jiÅ™Ã-matys-195a41a0
My gain ward gtx Titan just arrived.
Should I take out my gtx 580 or leave both cards in the workstation? Will this improve performance, for example using the gtx 580 for viewports and the Titan for RT?Reflect, repent and reboot.
Order shall return.
Originally posted by tammo View PostThanks, so do I have to setup windows to use my slower 580 as the display card and only use the Titan in RT?
Here is a step-by-step for selecting primary Windows 7 adapter:
http://www.ehow.com/how_8265360_chan...y-adapter.html
Best,
Brian
Originally posted by tammo View Post...Should I take out my gtx 580 or leave both cards in the workstation? Will this improve performance, for example using the gtx 580 for viewports and the Titan for RT?
With both cards rendering, If you have issues with the UI interactivity slowing down try reducing the Ray Bundle Size and Rays per Bundle in the Render setup dialog for RT. Or you can always disable (from GPU rendering) the display card with the included applet.
Things to watch out for would be driver compatability for both boards, having enough room and slots for both boards with adequate cooling, and a having a power supply big enough for both boards. And of course if you max out the RAM in the 580 you will have to just render on the Titan.
Also, you may need to have a dummy plug on the non-display card for Windows to see it...
Hope this helps,
-AlanLast edited by Alan Iglesias; 12-03-2013, 01:18 PM.
So I just picked up an Asus Titan today. 1m 46s - looking forward to test it some more and see how it performs in max' viewport.
Originally posted by Bpositive View PostSo I just picked up an Asus Titan today. 1m 46s - looking forward to test it some more and see how it performs in max' viewport.
