Nvidia Titan
  • okay, I ordered a Titan, and it arrived yesterday. in the middle of a crunch time, so I don't have time to compare that much... bad timing : )
    has anyone tried it in Maya and Adobe yet? is it safe to go for it instead of my Quadro 4000?
    • Mao let me know how the titan performs! It should destroy Quadro 4000 tbh.
      • Originally posted by Morbid Angel View Post
        you can probably hang on to it just in case I don't know about titan, only time will tell, but you have to keep in mind that the driver makes a difference too, quadro has its own driver, geforce its own, its a weird game they are playing
        They are playing bussiness:
        They handicap the Geforce by reducing viewport performance so you must buy a Quadro.
        They handicap the Quadro by reducing Cuda cores so you must buy a Tesla.
        They handicap the Tesla by not mounting a graphic port so you must buy a Quadro.
        Mostly it is all the same hardware, right now I am also looking into a Titan, I need the 6Gb for point clouds. Curious how it will perform on heavy CAD models and applications.
        • The Teslas usually do have a video output, but they provide no graphics acceleration...
          • Originally posted by raymarcher View Post
            Few persons said it was great, apparently considering this one, it's not that impressive, it's a shame they don't have done a comparaison with pro cards
            http://www.tomshardware.com/reviews/...tion,3474.html
            Stan
            3LP Team
            • Originally posted by 3LP View Post
              Stan
              I've seen that test too.. comparing different GTX-cards in pro apps but not including Quadros.....
              OR like this:
              http://www.game-debate.com/gpu/index...vs-quadro-6000
              where they compare GTX and Quadro but only in games...!
              No clear answers anywhere.
              • I recently purchased a boxx 4920 xtreme and got it with a titan card as the only graphics card in the system. There is a significantly large viewport performance improvement over my previous dual Xeon system with a quadro 5000. I don't have any numbers or stats to prove it, but I can say that I've always had laggy performance in cad when working with a large cad drawing and now they are buttery smooth. Not sure if the overclocked i7 has any impact or not. Based on my experience, I would recommend a Titan over a quadro.
                • Originally posted by jpmartin View Post
                  Do you use REVIT? I think REVIT and Max are a lot different in how they respond to graphics hardware/graphics drivers. I do think REVIT uses the CPU a lot for graphic display. Open your task manager and monitor your CPU usage.
                  • No, I don't use revit. Mostly Autocad 2011 and Max 2014.
                      And Maya shouldn't be much different to Max viewport wise?
                      • Anyone test new GTX 780? How is it go in GPGPU performance, in VRay RT?
                        AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
                        2D | 3D | web | video
                        jiri.matys@gmail.com
                        https://gumroad.com/jirimatys
                        https://www.artstation.com/jiri_matys
                        https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
                        https://www.instagram.com/jiri.matys_cgi/
                        https://www.behance.net/Jiri_Matys
                        https://cz.linkedin.com/in/jiří-matys-195a41a0
                        • Originally posted by fasterG View Post
                          They quite different...
                          • Man I want Titan so bad...But I just can't justify the $1k price for it right now...BUT I WANT!!!
                            Dmitry Vinnik
                            Silhouette Images Inc.
                            ShowReel:
                            • GTX 780 should be very close to Titan if NVIDIA didn't do something bad to it . I doubt that there will be 6GB version though, otherwise Titan would become pointless.
                              • For those not on a budget, NVIDIA's improved Titan
                                http://www.geeks3d.com/20130724/nvid...gk110-enabled/
