OK so after a big whoehaa and reading up etc about how wonderful Corsair is suppose to be, I finally got my stuff.
Corsair PSU
Corsair Vengeance RAM (4 modules)
Corsair Carbide 500R Case
Corsair H80i Cooler
Lets start with the case
It looks nice, and things appear to be arranged for easy access. But the back and inside has a very CHEAP plastic feel to it. Was afraid to touch the case otherwise it might crack
Then there's fitting the PSU. Its their own case and PSU but only 3 of the 4 screw holes line up. Even if you mount the PSU upside down, same story. The 4th is on the side and I put a screw in, but its just for show basically.
I managed to fit the H80i cooler at the back of the case OVER the ram with the high heatsinks, which is a plus point. It just just fits. The radiator actually touches the ram heatsinks.
Now the "wonderful" H80i cooler. The manual says that you can download a more detailed version and gives a URL. No downloads in that link! The manual says for best performance the fans should be mounted to suck IN air from the back. Also the manual says to check the arrow on the side of the fan for airflow direction. There's no arrows anywhere on those fans!!! OK fine then just follow the picture as per the manual? But the picture has it that the airflow blows out the case! Can't help to think this is one of those cheap chinese ENG"R"ISH translations for cheap stuff that they somehow get people to pay a premium for.
So which is it? Like most normal systems cold air gets sucked in from the front of the case and hot air gets blown out the back? But for this Corsair system? Suck in cold air from the back and blow hot air out the front? Or suck in cold air from front and back? Which is wrong? The translation of airflow direction or the 3D diagram showing the direction the fans should face?
I haven't actually plugged the power in and switched on to see if anything works yet. Hopefully low temps and quick render times will make me smile again and see why people are so fascinated with Corsair. So far I'm not impressed at all.
Corsair PSU
Corsair H80i Cooler
