Vray Lens effects bug?
  • Vray Lens effects bug?
    I tested a scene with lens effects enabled and RT GPU as production renderer. When rendered first, glare and bloom worked well when enabled the lens effects dialogue in the vfb. Then rendered once again, and lens effects doesn´t work. The lensEffectsSource channel stayed empty. Restarting Max - no success. Restarting the whole PC, all works fine again, but rendered a second one it fails.
    Any anwers?
    My specs: Max 2014, vray 3.0
    Best regards
    Michael Kaiser
    Yes, we already fixed this in a patch that we will upload next week; if you need the fix urgently, please email me to vlado@chaosgroup.com
      Thank you. It´s O.K. next week. I´m currently not in a important production in this case, was just testing a bit around there.
      Best regards
      Michael Kaiser
        Does this patch fix the material and object ID as well?
          To be more specific, you are talking about lens effects with Bloom/Glare masks with RT-GPU ?
          V-Ray fan.
          Looking busy around GPUs ...
          RTX ON
            Sorry I meant in general, currently the lens effects doesn't work with material ID and Object ID for production. Not sure about RT as I never tested it. I did speak to Vlado about it in a different thread so I wondered if the patch included the fix. http://forums.chaosgroup.com/showthr...ht=lens+effect
              Unfortunately it doesn't. It's a bit more work and we'll get to it, but there are a few small fires to put down first
                No worries, I have no immediate requirement for it, back to the old fashioned way of adding blooms and glares in PS for now.
