Noise treshold
  • Noise treshold
    Hey,
    I'm testing latest public RT build and found that noise threshold seems to work in wrong way. Does it take into account gamma set up in color mapping ?
    All settings are default. In RT threshold of 0.003 looks like 0.02 in ADV in dark parts, looks like it's checking out the noise in gamma 1.0 instead 2.2. Or is it just me ?
    Best,
    Tomasz
    @wyszolmirski | Dabarti | FB | BE
    I've read that noise threshold for progressive sampler does not work properly (info from Vlado). RT uses basically the same sampler so it might be the same problem.
    In exterior progressive sampler with noise 0.01 did just fine and in interior I needed 0.001 or even 0.
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
      Originally posted by wyszolmirski View Post
      I'm testing latest public RT build and found that noise threshold seems to work in wrong way. Does it take into account gamma set up in color mapping?
      It is broken in the official builds; things should work fine in the SP that's coming. If you want to give it a try, email me to vlado@chaosgroup.com
        Of course I want ! I've sent you an email.
        Best,
        Tomasz
