Rounded corners on the GPU (VrayEdgesTex)
  • #16
    Originally posted by tashko.zashev View Post
    Can you attache a simple scene file to have a look?
    I have sent it via email to you. But you can easily recreate it. Additionally, I checked it out farther a few minutes ago and it seems like if I half the values of the bump and normal maps, then I get half and half of each.
    • #17
      Thank you. We will check the file and get back to you shortly.
      Tashko Zashev | chaos.com
      • #18
        The plan was to add a bump slot inside the edges texture, but we ran out of time. Will add it for the patch next week.
        Hi Vlado,
        will this make it in the next SP?
        "I have not failed. I've just found 10,000 ways that won't work."
        Thomas A. Edison
        • #19
          Originally posted by eyepiz View Post
          Hi Vlado,
          Yes, good question. I have been downloading the nightlies, they are not there. Do they get added on the SP rather than nightlies?
          • #20
            The feature should appear in the nightlies first. Unfortunately it is not implemented yet, we are still working on it.
            Technical Support
            Chaos Group
            • #21
              any update for the nightlies yet?
              Thomas A. Edison
              • #22
                Yes, it should be there.
                • #23
                  It's not in the latest stable nightlies yet.
                  Thomas A. Edison
                  • #24
                    It should work with the latest nightly (stable) builds. Try to set it like this:
                    • #25
                      The VRaybumpmtl seems like an odd workaround to me.
                      Could the rounded edges not be added to "options" section of the vraymtl as a permanent feature? See attachment for dodgy photoshop hacked UI
                      That would then do away with having to use the VRayedgetex for rounded edges.
                      Chris Jackson
                      Shiftmedia
                      www.shiftmedia.sydney
                      • #26
                        That seems cool to me, having to do an extra map for every material is somewhat cumbersome and now having to do 3 maps to achieve rounded edges and bump at the same time, for every material... Chris' solution seems like a time saver, specially when you have a lot of materials to do like this.
                        • #27
                          I'll forward this request to the developers for consideration. Thank you for your feedback.
                          • #28
                            By the way, I tried this out. I like it, but it gives different results in Adv against RT. Its concerning because I want to be able to render in either engine, depending on what I have available at the moment.
                            Image on the left is RT, image on the right is Advance.
                            Best
                            alex
                            • #29
                              Nope, will not be doing that. We have a bunch of materials (car paint, physical material in max 2017, the alSurface one, skin material etc), I have no intention of adding rounded corners parameters to all of them. The VRayEdgesTex approach works well, it just needs some additions to be truly useful.
                              • #30
                                Is this not the plan anymore? a bump slot inside the edges texture would be ideal.
                                Thomas A. Edison
