Tests with GP100 and NVLINK
  • Tests with GP100 and NVLINK
    Chris published some tests with GP100 and NVLINK, so far it seems quite impressive:
    https://labs.chaosgroup.com/index.ph...e-nvidia-gpus/
    nvlink means, that we don't have ram problem anymore?
    CG Artist
      It means that the RAM on the GPUs is added together. You can still manage to overflow that
        What about cuda with shared memory ? I read pascal is able to use all the system mem.
        CG Artist
          Not with Intel CPUs...
            Hows that Like there's any other cpu available
            CG Artist
              Is there any word on whether this will be supported by the 10xx series? The article link made it sound like it's not yet...?
              thanks!
              Daniel
                It doesn't look like it.
                  Very interesting. It is a surprise to me because I didn't think NVLink worked with Intel CPU at all, but maybe the GP100 use PCI to connect to the Intel chipset and NVLink to talk to each other?
                    NVLink works between GPUs with those bridges https://www.workstationspecialist.co...ro-gp100-3.jpg. It doesn't work between the GPUs and Intel/AMD CPUs.
                    Best,
                    Blago.
                    V-Ray fan.
                    Looking busy around GPUs ...
                    RTX ON
                      Best,
                      Blago.
                      Ahh, thanks for the info. Would love it though if nVidia allowed Intel to use NVLink tech ifor their chipset instead of old school PCI connections now.
                        From what I gather, NVidia doesn't mind at all, but Intel will never allow it.
                          I'm about to starting testing two NVIDIA GP100s with NVLink.
                          What NVIDIA driver do you recommend I use?
                          Also, which version of Vray for Maya should I be using in order to take advantage of NVLink?
                          Thank you!
