Nice! Definitely post some sweet benchmark screens and let us know how it goes!
threadripper!
Somebody got 40 sec. on a 1950x. Nice!Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
Yeah i saw that, I get 2mins on my 8 core extreme intel so this is more than twice as fastWerT
www.dvstudios.com.au
I just bought a 1950x. Good first impressions. 48sec benchmark with no OCing.
My intel laptop buckets appear the same as my AMD computers when DBRing.
Note: if you can't get windows 10 to install on the new hardware - download the latest windows via windows media creation tool and tell it to create a bootable USB. I have a retail version on USB that stopped at the blue windows logo.
If you can't even get to bios then pull a couple of sticks of ram out and then update your bios.
Originally posted by Richard7666 View PostIs anyone here using the Gigabyte Aorus X399? (I figure there's a fair chance because there are only 5 or so motherboards out at present)
If so, are you able to find a cooler that doesn't obstruct the nearest RAM slots?
no, no integrated. Ryzen doesn't have integrated either (and neither does Intel in this range). Remember, these are HEDT/workstation (high end desk top) class chips, and that isn't usually required - they figure "hey, if they are dropping minimum $1,000 on a cpu alone, then they can afford a $50 standalone gpu card to get the job done"
Originally posted by delineator View Postno, no integrated. Ryzen doesn't have integrated either (and neither does Intel in this range). Remember, these are HEDT/workstation (high end desk top) class chips, and that isn't usually required - they figure "hey, if they are dropping minimum $1,000 on a cpu alone, then they can afford a $50 standalone gpu card to get the job done"
Allright! we orderer 5 x 1950x systems and 2 come with 2x 1080ti.. i hope distributed RT rendering with the cards in different systems works good.. if so we still can put 6 more in the 3 render boxes that have only a passiv 1030 placeholder sausage card.
cant wait to get it running and also switching back to 3dsmax 2016 for production. I am done with 2017 and 2018.. its garbage.
I am super excited! And with 2 1080ti it should be Vieportworking 2.0.
Ill try OC too if its kind of stable but if its making too much heat than ill leave it. We have the biggest 3 fan watercooling stuff on the cpu so it should stay ok when using for more than a day rendering.
====Thanks for a lot of infos here regarding Threadripper stuff!! this helped me a lot! Thanks Guys!
Seeya, DanielDaniel Krassnig / http://www.vistral-3d-visualisierung.de/ / Architektur Visualisierungen
What clock speeds are you guys getting when maxed out at full load? For a few weeks while mine was rendering with all cores clocked at 3.7Ghz.
My current animation camera path is only clocking all cores to 3.55Ghz. I haven't figured out a pattern yet as to why it runs faster at times. Heat isn't an issue - because I've installed air conditioning in my office and I've only noticed the slower speed after installing it.
have two near identical systems running at the same clock speed - I built the second one a few days ago.
I've just got the Threadripper.At stock frequency that thing is more than 3 times faster than my old CPU (6-core 4930k), wow! I can get 3.9-4.0 Ghz with Noctua NH-D14S.
DPS If I don't overclock mine it stays between 3.4 and 3.7 Ghz under load, just like you observed yourself. Interestingly, when idle it stays at 3.9-4.0 Ghz.Last edited by Alex_M; 30-09-2017, 05:55 AM.Aleksandar Mitov
96GB DDR5
Alex_M With regard to your clock speeds when rendering - are all cores hitting 3.7GHz under full load? Mine were doing this but now in vray they only seem to be clicking to 3.5GHz.
They go up to 4GHz + when doing other tasks. Including all cores at 3.7 so im wondering whether it's somehow related to particular vray usuage.
Stupendousman you don't need to doing anything to overclock it - it does this automatically.Last edited by DPS; 30-09-2017, 01:25 AM.
