GPU CUDA support Maya utility nodes
  • GPU CUDA support Maya utility nodes
    Maya 2017 U4 & Vray for Maya 3.6 stable nightly 27496
    NVIDIA GP100 (enabled) + Quadro M6000 (not enabled)
    Is there a list somewhere of which Maya 2017 utility nodes are support when the Production Render Engine is set to CUDA GPU?
    I was able to find this but it doesn't seem to mention the Maya utility nodes: https://docs.chaosgroup.com/display/...orted+Features
    Thanks!
    I'll make a note into our system to add utility nodes into the supported features list.
    As for now we don't have any official information what is supported and what's not.
    Are you looking for some specific nodes or you would like to know for all of them?
      Ideally, I would like to know all of them, but for now, can you tell me if the following are supported by GPU CUDA:
      - Contrast
      - Clamp
      - Gamma Correct
      - Luminance
      - Ramp Color
      - Remap Color
      - Remap HSV
      - Remap Value
      - Sampler info
      - Mutiplydivide
      - blend color
      - plusMinusAverage
      - Reverse Value
      - Surface Luminance
      - HSV to RGB
      Thank you for your help.
        Would still like to know if the above Maya utilities are supported by Vray GPU CUDA.
          Yes, sorry for the delay. Will check case-by-case and get back.
          Best,
          Blago.
          V-Ray fan.
          Looking busy around GPUs ...
          RTX ON
            Hello, this is the info for the nodes you wanted:
            Contrast - NOT supported
            Clamp - SUPPORTED
            Gamma Correct - SUPPORTED
            Luminance - SUPPORTED
            Ramp Color - Here if you mean the Ramp texture, yes we support it
            Remap Color - SUPPORTED
            Remap HSV - SUPPORTED
            Remap Value - SUPPORTED
            Sampler info:
            - UV Coord - SUPPORTED
            - Tangent VCamera - NOT supported
            - Tangent UCamera - NOT supported
            - Point World - SUPPORTED
            - Point Obj - NOT supported
            - Point Camera - SUPPORTED
            - Pixel Center - NOT supported
            - Normal Camera - SUPPORTED
            - Ray Direction - NOT supported
            Mutiplydivide:
            - No operation - NOT supported
            - Multiply - SUPPORTED
            - Divide - SUPPORTED
            - Power - SUPPORTED
            blend color - SUPPORTED
            plusMinusAverage:
            - Input 1D - NOT supported
            - Input 2D - NOT supported
            - Input 3D - SUPPORTED
            Reverse Value - SUPPORTED
            Surface Luminance - NOT supported
            HSV to RGB - SUPPORTED
            Chaos Vantage and V-Ray for Unreal Team Lead
            vladislav.vulchev@chaosgroup.com
              This is awesome. Thank you so much!
              I recommend you add this to the manual.
