Quicktime Objectpanorame , how ?
  • #16
    Hi Tom,
    Just wondering where you got to with QTVR OBJECTS ?... I have been looking for a script that sets cameras up around an dobject but without luck....... love to see some examples... Cheers.
    • #17
      Hi Robur,
      I don't have a script but its quite easy to draw a circle and use it as a path constraint for a free camera. Then use 'track view' to change the animation length in frames. You've got to make sure all your tangents are set to linear for a smooth frame sequence.
      Hope thats some use.
      Dan
      Dan Brew
      • #18
        Hi Dan,
        That's a very good tip, thank you. I guess you could do the same for the vertical rotation.
        Cheers.
        • #19
          maxVR.qt 2.0 does work with Max 7, and it will place as many cameras as you need on all points of a sphere so you can pan up and down not just side to side. the caveat is that it does not work in backburner so all images have to be rendered localy on a single box.
          Eric Boer
          Dev
