Asphalt Roof Edge
  • Asphalt Roof Edge
    I am dying with asphalt roof edges. Does anyone have any tips? I have some luck with drawing a line and center offsetting it. Then I grab the edges and drop it down, eyeing things, but unless it is a straight roof edge, it never really works right. I have tried the same line center offset and shape merging, but MAX is really bad at it and most of the time it fails and only cuts part of my roof. A roof with dozens of edges can take hours. I know there is a way because the roof displacement script did it in seconds, but that script has gone dead a decade ago.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    example please?
    Marcin Piotrowski
    youtube
      I think this might help you;
      http://www.scriptspot.com/3ds-max/sc...o-tools-atiles
      The default is not asphalt, but you can make it custom.
      Haven't used it in a while, but from what I remember, it was working fine for edges.
      Alain Blanchette
      www.pixistudio.com
        Yeah, I have tried this and almost everything else. For other types, this script work great. Even Railclone doesn't have a simple asphalt roof with ridge cap which is odd to me. In the states, 95% of your roofs will be asphalt shingles.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          https://www.digitalxmodels.com/produ...free-maxscript
          show me the money!!
            Yes, that is the one that broke after MAX 2009
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Originally posted by piotrus3333 View Post
              example please?
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Now, mind you, simple roofs are quick, but when you get into roofs like above it becomes a nightmare. I just did a roof with 9 ridges, all with the same pitch and it took me a few minutes. It's the above-complicated roofs that can take many hours.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  railClone seems to be an obvious choice here.
                  Marcin Piotrowski
                  youtube
                    I reached out to them and asked why they don't have a simple asphalt roof. They said that they can't create a roof type of every roof style, but I said that 95% of the roofs in the states are asphalt. That was months ago and I haven't heard back. I don't know RailClone well enough to build my own style. Simple roofs yes, but roofs where the pitch is different on each side of the roof isn't so easy.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Paul roberts from itoo (the lovely man) had a script and a vimeo video for it - https://www.itoosoft.com/tutorials/c...3D2%26tag%3Drc
                        Yes, but those are simple ridge caps. If you have hip caps with each side being a different pitch, it is a pain.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          would displacement work for you or it needs to be geo?
                          Marcin Piotrowski
                          youtube
                            I do use displacement for my roofs.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Wow, thats an odd way to roof a house... Nah, americans
