Asphalt Roof Edge
  • #16
    That's the roof you'll see on 95% of the houses.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      I reached out to them and asked why they don't have a simple asphalt roof. They said that they can't create a roof type of every roof style, but I said that 95% of the roofs in the states are asphalt. That was months ago and I haven't heard back. I don't know RailClone well enough to build my own style. Simple roofs yes, but roofs where the pitch is different on each side of the roof isn't so easy.
      maybe because USA is not the center of the world
      show me the money!!
      • #18
        If you were to create one roof style for the states it would be this, an asphalt roof. Sure, we are not the center, however, I am sure they sell a few copies of RailClone to the states.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #19
          HAHA! Neither are asphalt shingles!!!
          • #20
            If you have a script that does this in previous version of 3d max, why not just install that previous version of max with the script and use it to do what you need instead of creating this long hot mess of a thread?
            • #21
              I am not sure why you would see it as a hot mess of a thread. it is a need that I am sure many have. If I could find MAX 2009. I already went down that road.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                I did this roof some time ago by selecting the roof planes, copy detaching them to connected polys, selecting the ridges and then extrude the edges the distance (while keeping height=0) I wanted.When deleting the lower polys you're just left with the ridge polys which you can displace after mapping them correctly. There is a bit of a rounding error (<1%) when you have falling/rising ridges but that should not be such a big problem.
                • #23
                  i am very busy right now, but perhaps this is something for you.
                  Max 2019 and Railclone required
                  • #24
                    I am not sure I understand, but I'll try.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      Originally posted by 3D-Casi View Post
                      I tried railclone several time, but each time there was an issue. I'll play around with yours, thank you!
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #26
                        I don’t even remember how I did this roof. It was a couple years ago, but however I did it, it was successful. I need to spend some time to get down some steps.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          On Railclone, you can have the 2S array aligned to the boundary spline. This is for the tiles.
                          Then just pick out the relevant splines to use as the ridges etc and a RC linear array on them ?
                          • #28
                            • #29
                              I also hate doing ridges and don't have rail clone.
                              @tricks method could work but also I just was playing around with another method that's quite simple and works for any type.
                              You can either make a run of say 50 ridge tiles and attach them all, then use a path deform on a spline snapped to whatever ridge it is. Or equally fine is to use the spacing tool on that spline. Further refinement if necessary on a sub-object local level for one or simple local transforms for the other.
                              • #30
                                God I would hate to do this without railclone. The cost of RC is nothing compared to the frustration of having to do this manually.
                                A.
                                www.digitaltwins.be
