Best Trees
  • #16
    yeah, it's a really tough one...I agree with others mostly...I get from an assortment of already mentioned vendors, but lately I'm most enjoying Laubwerk sample kit1 very much, as well as some I've found on 3dsky....
    I always want to check out GrowFX, but I've honestly got no spare time to build trees and plants.
    • #17
      I purchased some Laubwerk libraries, but they were late on the last couple MAX releases. Also, creating proxies never work, at least for me.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
      • #18
        Hey Bobby, that's good to know, thank you!
        P.S. Any luck using them as Xrefs instead? (Assuming you're plugin them into FPP?)
        • #19
          I didn't play too much with them and you might be able to proxy and Xref them, but it wasn't immediately obvious.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #20
            Most of the packages are hit/miss, imo, but I agree, MaxTree are pretty solid.
            voltron7 Laubwerk successfully plugs in to FPP with Xrefs
            • #21
              I was *very* happy with speedtree cinema, when i last used it.
              Loathing opacity maps, and favouring polygons, i found it pretty easy to make my own leaves and needles, in the millions and millions. ^^
              Lele
              emanuele.lecchi@chaos.com
              Disclaimer:
              • #22
                I did buy GrowFx and two of their libraries. They are heavy and seem out of scale, but I am new to it.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  Maxtrees are very good, very nice materials now. CGAxis are terrible, bad models, even worst materials and textures. Evermotion has two or three packs with very good models.
                  And GrowFX is very good plugin. When you buy some collections with GrowFX files, its really easy to make your own from them.
                  AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
                  2D | 3D | web | video
                  jiri.matys@gmail.com
                  https://gumroad.com/jirimatys
                  https://www.artstation.com/jiri_matys
                  https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
                  https://www.instagram.com/jiri.matys_cgi/
                  https://www.behance.net/Jiri_Matys
                  https://cz.linkedin.com/in/jiří-matys-195a41a0
                  • #24
                    I purchased some iCube libraries. Especially the fir trees look very similar, we commonly have here.
                    • #25
                      Have you tried iToo The3DGarden pack? https://www.itoosoft.com/store/the3dgarden
                      Available for remote work.
                      My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
                      • #26
                        I have several of their libraries. Always pretty good.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          I needed a forest and meadow for my ongoing project. I created this with the Multiscatter plug-in. I used VRaySky for background adn VRay sun for lightning. I might want to create a photosphere for more realistic sky.
                          • #28
                            Here is a good tip:
                            do to 3dsky and look for user called Istwood15
                            probably the best trees foliage models ive seen
                            Martin
                            http://www.pixelbox.cz
                            • #29
                              Originally posted by PIXELBOX_SRO View Post
                              Here is a good tip:
                              I bought a couple of models from that guy. Some of them had quite poor textures and materials applied. Though generally they are not bad.
                              • #30
                                O guess those were earlier models? The latest conifers and evergreens look spot on
                                Martin
