SketchUp Madness
  • SketchUp Madness
    I am going to travel the globe smacking SketchUp out of un qualified hands. What the hell! Any recommended scripts to try to automate the cleanup? Flipped normals and double faces everywhere I look.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    im feeling ya, I end up basically remodelling the whole thing, just using it as scale reference.
    e: info@adriandenne.com
    w: www.adriandenne.com
      That's what I am having to do. It's a huge site, so it's madness. I mean, everything is wrong with this model and they couldn't have done worse if the tried.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Don't blame SketchUp...fatal user error
        https://www.youtube.com/watch?v=Aohif7AjuBw
        show me the money!!
          I quoted a couple of times based on the fact they had a sketchup model...from the architects themselves. I very wrongly assumed they would know what they were doing.
          I was so wrong and it was an awful, awful mess. I felt honour-bound to stick to my quote and so put up with the nonsense.
          Needless to say, never again. Only useful as a template imo.
            I questioned this architect and he said that his guys are the best in the business. I told him that I'll quote based on a flattened set of documents; he wanted a discount, which I didn't give to him.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              ...the best in what business though? That's the question. Maybe they're actually bakers and their cakes are awesome!?
                Put it this way, if their cakes taste as bad as their SketchUp model is built we are in trouble and there will be some lawsuits.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  I only quote based on the SketchUp I receive and explain to them why it isn't usable in case of these kind of things. Only 10% of the models I receive are somewhat usable. If I'm lucky they draw with components and it's easy to add adjustements/detail or replace the whole thing. SketchUp is a wonderful tool to model with (if not too organic). But it can be completely miss used, unfortunately that's almost always the case.
                  A.
                  www.digitaltwins.be
                    I have found joining everything in MAX and editing poly using the material ID is easiest. If I join everything and pick the id for, let's say grass and detach it, works well.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Lucky you! LOL in one of those I got stuffed on, the model I got had, for instance, parts of the brickwork connected to completely different other parts of the geometry which had a different material or even multi-mat, all of which were duplicated and uniquely named.
                      This was true of the entire model and it is bewildering to me that someone managed to screw it up to such a degree. It was impossible to pull apart and so I pretty much had to scrap the lot.
                      As I said, lesson learned
                        When I ran my material to layer script, every element had a unique material, even though the materials were the same. For instance, the same brick, but every element with brick and had different brick material. After I cleaned everything up I had to delete a couple of thousand layers.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          It's a little bizarre that there is simply software existing that serves to partially mitigate others' errors
                            are you guys using 3ds max importer for su files?
                            Marcin Piotrowski
                            youtube
                            CGI OCIO config 04
                            • #15
                              Yes, and I am on MAX 2020. I just imported a site plan and each poly is an element and the normals are arbitrarily flipped all over the place.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
