PSD Manager V-Ray 5
  • PSD Manager V-Ray 5
    So, while the PSD Manager folks work on an update, I have a question. How hard would it be for someone to write a script to creates a mask from MAX layers? This is what I use PSD Manager for and it seems like it should have been done already.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Bobby, have you looked into Cryptomatte?
      No, but I will. Thanks!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I remember seeing this. Kind of techie... I don’t see a way to buy it or anything.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Cryptomatte is shit, it's super slow.
          We have a custom script, it's pretty straightforward to script a photoshop import. You could record a macro that breaks each RGB layer into 3 masked folders pretty easily.
          The pulse post manager is an improved version of what we use in-house - you should check it out. it might take a minute to get used to the way it wants you to work, but offers a lot of flexibility for updating.
          https://pulze.io/products/post-manager
            Interesting, will look into that. In the meanwhile, cryptomatte is already built in as a Vray render element and creates these masks for you in you EXR, which you then open in Photoshop. I've found it very useful as I don't need to depend on a plugin like PSD Manager. It never occured to me that it was slow, never compared.
            https://evermotion.org/tutorials/sho...ax-cryptomatte
              I personally use Cryptomatte too .
              in Photoshop you won't have the performance issues comparing to Aftereffect and animations especially with hundred of masks .
              just use the free EXRIO plugin for Photoshop and you can have masks however you want ( per instance, per material , per layer ..etc)
              I usually only need mask for few objects so I did write this script to that in one click (download link in the description )
              https://www.youtube.com/watch?v=Q9iq6iiN8FA.
              The Pulze post manager is very good solution too, but I try to avoid subscription based tools when I can even tho it is cheap ...anyway that's another story.
              They promised few months back to release one-time-payment license, but it is not available yet.
              Simply, I love to put pixels together! Sounds easy right : ))
              Sketchbook-1 /Sketchbook-2 / Behance / Facebook
                Cryptomatte worked perfectly! GPU isn't supported, but that's okay. I'll try Pulze when I get a chance.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  for those with already too many plugins: shallow knockout in photoshop’s layer blending options cutting through whole one layer group instead of mask. basically “color to alpha” functionality.
                  Marcin Piotrowski
                  youtube
                  CGI OCIO config 04
                    I don't understand, can you elaborate?
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Of course if you just need a few mattes you can use one or more MultiMatteElement render elements. (Give a unique name to each of you are auto saving the layers).
                      They can be set to use object IDs or material IDs. Pretty easy to work with. You can add one for IDs 1,2,3, another for IDs 4,5,6, etc. gets tedious if you need more than ten or twenty, but generally I think you should be spending more time getting things right in Max if that is the case
                        A little darker her and a little lighter here... tweak the color there... My clients seem to be picky and having all my layers already masked, just in case, is a major time saver.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          I just had a client call yesterday saying that they decided to go from a gray roof to a black roof, which took me 10 seconds in Photoshop. CTRL+Click the roof mask layer with a level adjustment, and done.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            No doubt masks and layers are great when they work!
                            In VFX sometimes they don’t work well due to motion blur or depth of field, etc.
                            • #15
                              Just houses and building stills here All day, all night, 24/7/365.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
