Animation prices
  • Animation prices
    This gets asked often, but I don't think there is ever a consensus. What are people charging for animations like this?
    https://www.youtube.com/watch?v=W7Gv...ature=youtu.be
    Not the best, but my client sent it as an example of what he is looking for. I remember reading animations can go from $100 to $400 per second, and up. So, a 4-minute animation would be around $24,000 - $96,000; however, this one would be on the lower end of those numbers.
    I looked at the RTX 3090's and if you can find them, they are from scalpers and marked up to around $2000. A couple of these might make short work of it and would save dealing with a render farm.
    What are your thoughts?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hmm, I would think good luck getting $24K+ for that. This looks more like Enscape or Lumion than something rendered.
      One of those might be the solution.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        What are your thoughts ?
        Jez
        3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
        Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
        Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
        ---- Updated 06/09/23 -------
          I think that they are a lot of work when doing them conventionally. Vantage I don't think is the answer yet, but maybe one of the other suggested softwares.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            i dont see it being majorly different than doing it in vray.. its not like the old days where you had to wrestle with vray settings and hacks to get a clean animation. set up your cameras, animate them (the ones in your example are literally two keyframes each camera.) , set it to render. maybe tweak the AAmin rate, and lightcache settings as suggested in the tooltips.. if your scenes are set up for gpu you can probably bash out something like that overnight on one workstation.
            your price estimate seems a touch high for this day and age... 10-15 years ago it was that and even much more... nowadays, on a scene which has already been built, i usually charge about 2-3x the price of a still for each shot, with render costs seperate if i need to use a farm..
              looks very Lumion. fake gi. this would be pretty fast with vray but cpu only - gpu still lacks VRayAmbientLight.
              Marcin Piotrowski
              youtube
              CGI OCIO config 04
                I have never gotten a clean animation in a time that made sense in V-Ray. Maybe, I am just not got at it. So, what would you all be charging for the 4-minute animation, like the one he referenced.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  you'd have to have a decent farm to render 4mins out overnight surely?
                  e: info@adriandenne.com
                  w: www.adriandenne.com
                    Yeah,I wouldn’t expect four minutes overnight, but I’m not sure if I could do one of the segments over night.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Personally, I would get it set up for the best acceptable quality/frame time and then check that total render cost on a farm calculator.
                      A quick estimate I just did with Rebus, at 5min per frame (6000 frames, cpu render), based on your spec is around 2k USD. That would vary per frame of course, so adjust for that.
                      Add on your margin for the organisation, optimising/testing, previews etc. plus whatever more for fixing errors, comping, extra frame time and beer
                        I have had bad experiences with render farms. I have had projects estimated for X and it ends up being 4X more expensive, being told a frame got stuck or something. Uploading assets and then of course last-minute changes after the animation is completed.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Yeah, I'd be very surprised if 6000 frames came out as $2k.
                          What resolution?
                          Jez
                            I wouldn't have him expect anything more that 1080P
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              The calculator doesn't care about the frame size, only the time taken for a frame; so if your chosen frame at whatever resolution takes 5 minutes on your machine spec, then the calc is based on that.
                              It is mostly reliable if you average the times between simpler sections and harder sections.
                              You can try it yourself of course - you just need an account registered
                              EDIT: Yes, trusting anything to a farm is a judgement call, though it is a robust and widely used service and as long as your tests and scene checking is good, then there shouldn't be problems.
                              I've used this one a lot in the past and had no issues other than an overcharge based on not enough testing having been done. Still, the project could not have been done without it and the costs were
                              covered.
