dont forget the frame rate too when calculating.
Animation prices
Originally posted by fixeighted View PostThe calculator doesn't care about the frame size.
You need to know what resolution you need, you test run your machine at that resolution (across a variety of scene moments) and then put the highest / the average of those into the calculator.
Otherwise, yes, you will get a surprise outcome....
Jez
3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
---- Updated 06/09/23 -------
Originally posted by glorybound View PostI think that they are a lot of work when doing them conventionally. Vantage I don't think is the answer yet, but maybe one of the other suggested softwares.
Jez
Originally posted by JezUK View Post
The calculator might not care about the frame size but you sure should. The frame size is vital - otherwise the calculation is rather meaningless.
There simply is no other way and I have experience over years of doing just this
Anyway, it was merely a suggestion based on the initial question.
No, I meant what are your thoughts regarding pricing, what prices are you thinking you would charge?Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Oh I've been there, I know all too well how quickly South these can go which is why I rarely do them, unless the budget is there.
Might be worth asking your client if they have a budget or price in mind?
Or give them a range of what it could cost and then gauge from their reaction.
Might save some time.
The last three animation I did I didn't make any money from.
Each one different and a one off. At least yours are more specific and I'd say more predictable.Last edited by JezUK; 27-01-2021, 09:17 AM.Jez
For a residential spec, tell them you can do it for 15k which will include X still images. Produce the X still images first and have them sign off on those in writing before producing the animation so you are:
A.) not consuming more computational resources than needed to render out the animation
B.) should they make changes once the animation is produced from the still images they signed off on, you have ample jurisdiction to charge for any change order(s) incurred
Best of luck out there! Stay safe!
- Likes 1
is anyone taking into account that if quality of this sample is satisfactory for the client then after modelling all that producing imo better looking output takes a day or two of work and 400-500$ worth of software (D5)?
using vray for this seems like quite an overkill.
edit: also any rtx card but that should be easy I guess.Last edited by piotrus3333; 27-01-2021, 11:37 AM.
- Likes 1
Originally posted by fixeighted View PostD5 does certainly look impressive. Will have to give it a go on my impending monster project. Thanks for the pointer
consider lumion or twinmotion for something “monster”.
Good to know. I just installed it anyway, so will see what it can do.
It's based on Unreal, which coincidentally is what the project currently is using
for testing, so it may be useful. If I can avoid having to put the animation through Vray I will
If it works, then I can come back to this post to offer findings which might help with determining
costs that don't make clients run away
D5, never heard of it, but I’ll check it out.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Everything seems to be going towards Lumion. I was hoping Vantage would be a Lumion killer, but maybe not, at least not yet. I have downloaded it a few times, but who has time to learn new software.... but I might not have a choice.Bobby Parker
phone: 2188206812
- Windows 11 Pro
