Remove Scale
  • Remove Scale
    I have a few scenes, each with 100's of materials, and all have their real-world scaling. Now, I have to remove all the real-word scales and drive the scale with the UVW MAP. Is there a way I can remove all the real-world scale on all my materials? Please say yes!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    https://www.scriptspot.com/3ds-max/s...terial-control
      I use that all time, I'll see what it can do for me. Thank you!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        This is the setting in particular you're after
          I love seeing posts like this
          Set V-Ray class properties en masse with the VMC script
          Follow me for script updates: @ollyspolys
            is this for realtime Bobby?
            if so, then you can leave the UVMap modifier to realworld scale, but in the textures just switch off realworld scale, which will give you the equivalent U and V values for example 0.5 or 0.025 or whataver. Then you can feed those exact values into your tiling in your realtime engine's textures
            Kind Regards,
            Morne
