3dsMax scripting question
  • 3dsMax scripting question
    Hey guys,
    does anyone know a script that does the following:
    - take all the materials assigned to a scene
    - for each material, select the objects that have that material assigned
    - collapse them into a single mesh
    I tried my best to get something out of ChatGPT and the likes, but I only get some kind of pseudo-code.
    Sadly my knowledge of MaxScript is so bad I don't even know where to start from.
    I believe sini scripts has the ability to do that. Combine by material… I haven’t used it in a while but remember collapsing revit models into material groups that way. Which at the time was worth its weight in gold.
      Try this:
      Code:
      allMat = for m in scenematerials collect m
      for i=1 to allMat.count do (
      select (for j in objects where (j.material == allMat[i]) collect j)
      collapse.setDoBool false
      collapse.setOutputType #Mesh
      collapse.setCollapseTo #Single
      collapse.doCollapse $
        Thanks for the help!
        Unfortunately, I can not get this code to work as expected.
        Attached you will find a scene with some objects and 4 materials. When I run the code, some teapots will dissappear, but no objects are collapsed.
        mat_collapse.zip
          Works fine on my end. Check the attached gif. Have I misunderstood you?
            Hi Aleksandar,
            on your end it is working as expected indeed!
            Will try again, maybe I did something wrong.
              Well,
              it is weird. On my end, nothing happens. But the listener is listing some errors:
              Code:
              #(01 - Default:Physical_Material, 02 - Default:Physical_Material, 04 - Default:Physical_Material, 03 - Default:Physical_Material)
              -- Error occurred in anonymous codeblock; filename: ; position: 256; line: 8
              -- Type error: Call needs function or class, got: OK
              -- MAXScript callstack:
              --    thread data: threadID:43856
              --    [stack level: 0]
              --    In i loop; filename: ; position: 257; line: 8
              --        Parameters:
              --            i: 1
              --        Locals:
              --            i: 1
              --            ​: undefined
              --        Externals:
              --            owner: undefined
              --    [stack level: 1]
              --    called from top-level
              I am on the latest version of 3dsMax 2025 if it help.s
                Is the Collapse utility loaded on your end? Check the Plug-in Manager for the Utility.dlu. Check for typos, missing brackets, etc. Also try adding this line between line 3 and 4 and see if that makes any difference:
                Code:
                utilitypanel.openutility collapse
                  Thanks for the help.
                  Sadly I can not get this to work.
                  The script is still throwing errors while having no effect.
                    Try this:
                    Code:
                    local allMat = for m in scenematerials collect m
                      [ATTACH]n1211342[/ATTACH]
                      same here. objects disappear.
                      max 2024.
                      Marcin Piotrowski
                      youtube
                      CGI OCIO config 04
                        Yeah, SINI has that in their suite of scripts. You can attach my layer, material, and selection. It is a priceless group of scripts.
                        Bobby Parker
                        www.bobby-parker.com
                        e-mail: info@bobby-parker.com
                        phone: 2188206812
                        My current hardware setup:
                        • Ryzen 9 5900x CPU
                        • 128gb Vengeance RGB Pro RAM
                        • NVIDIA GeForce RTX 4090 X2
                        • ​Windows 11 Pro
