3dsMax scripting question
  • 3dsMax scripting question
    Hey guys,
    does anyone know a script that does the following:
    - take all the materials assigned to a scene
    - for each material, select the objects that have that material assigned
    - collapse them into a single mesh
    I tried my best to get something out of ChatGPT and the likes, but I only get some kind of pseudo-code.
    Sadly my knowledge of MaxScript is so bad I don't even know where to start from.
    I believe sini scripts has the ability to do that. Combine by material… I haven’t used it in a while but remember collapsing revit models into material groups that way. Which at the time was worth its weight in gold.
      Try this:
      Code:
      allMat = for m in scenematerials collect m
      for i=1 to allMat.count do (
      select (for j in objects where (j.material == allMat[i]) collect j)
      collapse.setDoBool false
      collapse.setOutputType #Mesh
      collapse.setCollapseTo #Single
      collapse.doCollapse $
        Thanks for the help!
        Unfortunately, I can not get this code to work as expected.
        Attached you will find a scene with some objects and 4 materials. When I run the code, some teapots will dissappear, but no objects are collapsed.
        mat_collapse.zip
          Works fine on my end. Check the attached gif. Have I misunderstood you?
            Hi Aleksandar,
            on your end it is working as expected indeed!
            Will try again, maybe I did something wrong.
              Well,
              it is weird. On my end, nothing happens. But the listener is listing some errors:
              Code:
              #(01 - Default:Physical_Material, 02 - Default:Physical_Material, 04 - Default:Physical_Material, 03 - Default:Physical_Material)
              -- Error occurred in anonymous codeblock; filename: ; position: 256; line: 8
              -- Type error: Call needs function or class, got: OK
              -- MAXScript callstack:
              --    thread data: threadID:43856
              --    [stack level: 0]
              --    In i loop; filename: ; position: 257; line: 8
              --        Parameters:
              --            i: 1
              --        Locals:
              --            i: 1
              --            ​: undefined
              --        Externals:
              --            owner: undefined
              --    [stack level: 1]
              --    called from top-level
              I am on the latest version of 3dsMax 2025 if it help.s
                Is the Collapse utility loaded on your end? Check the Plug-in Manager for the Utility.dlu. Check for typos, missing brackets, etc. Also try adding this line between line 3 and 4 and see if that makes any difference:
                Code:
                utilitypanel.openutility collapse
                  Thanks for the help.
                  Sadly I can not get this to work.
                  The script is still throwing errors while having no effect.
                    Try this:
                    Code:
                    local allMat = for m in scenematerials collect m
                      [ATTACH]n1211342[/ATTACH]
                      same here. objects disappear.
                      max 2024.
                      Marcin Piotrowski
                      youtube
                        Yeah, SINI has that in their suite of scripts. You can attach my layer, material, and selection. It is a priceless group of scripts.
                        Bobby Parker
                        www.bobby-parker.com
                        e-mail: info@bobby-parker.com
                        phone: 2188206812
                        My current hardware setup:
                        • Ryzen 9 5900x CPU
                        • 128gb Vengeance RGB Pro RAM
                        • NVIDIA GeForce RTX 4090
                        • ​Windows 11 Pro
