looking for high quality wood textures
  • looking for high quality wood textures
    Does anyone know where I can get/purchase high quality veneer textures for:
    olive
    cherry
    mahogany
    oak
    does not matter if they are not free, most important is that they are of high quality and have a few variants. Thanks for your help
    You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
    http://www.veneerselector.com have loads of wood textures - depends how high res you mean when you say high res though...
    when the going gets weird, the weird turn pro - hunter s. thompson
      They are not tileable yet, but here are the biggest woodscans i found so far (most are about 3.200x2000)....and the best thing is they are absolutely free :P
      http://www.defcon-x.de/wordpress/textures/
      Hope it helps.
      Regards,
      Thorsten
          @instinct - ok you win!
            veneerselector I knew about. the other link is fantastic, thanks instinct
            BUT:
            still looking for larger pieces. Although the textures are high res, the actual real size is not so big, same as with veneerselector. I can of course do some paintwork on them to enlarge, but I prefer real large photographed samples to cut away rather than to tile.
              btw, does anyone know if it is possible to make a shader that changes color depending on viewing angle+orientation. Many veneers have this property.
              To make more clear what I mean: if you keep a sample under the same viewing angle and rotate it 180 degrees, the light and darker tones should switch.
                I have these and they are very large samples (2 meters high)
                http://www.highdimensiontexture.com/home.html
                Chris
                The Revitlution
                  Regarding the colourchange. Simply use a falloff material. to change them according tho the angle between camera-vector and surface normal.
                  Regards,
                  Thorsten
                    thanks, I forgot about these, I once downloaded the sample and that realy looked good. I build floor texture from it
                    Unfortunately they don't have the type of woods I am looking after.
                    @instinct: what you mean doen't work, because the dark-light pattern should switch for example when you change your view from 45 degrees to -45 degrees. With a falloff, you cannot make a difference between these two.
