Combustion encoders
  • Combustion encoders
    Does anybody know how to add more encoders to Combustion? I would like to be able to add Windows Media 9, DivX, etc. but I haven't been able figure that out. I would be kind of upset if they expect you to buy the $600 Cleaner XL for that kind of capability.
    Tim Nelson
    timnelson3d.com
    Just install the codecs on your box and combustion will recognize them.
    Eric Boer
    Dev
      Yeah, thats what I thought...I installed the WM9 encoder - twice, and still nothing. I haven't tried a DivX encoder yet.
      Tim Nelson
      timnelson3d.com
        Ok, the DivX works, so it must be something with wm9. Unfortunately, wm9 is the one I really need so because most people do not have divx.
        Tim Nelson
        timnelson3d.com
          Hmm, it works on our boxes here and on my box at home, did you scroll all the way down it's usually one of the last ones, oh and it's an avi not a wmv, just uses the wm9 codec.
          Eric Boer
          Dev
            Man, I must be doing something wrong, because I've tried installing wm9 encoder on 2 computers and still can't get it to show up in combustion. Is there a certain folder that the wm9 files should be copied into or what?
            As far as DivX, I got the encoder to show up, but it only made a 64k movie and would not play in the DivX player. So thats screwed up too!
            Tim Nelson
            timnelson3d.com
              Eric, what menu do you go to to see the wm9 encoding option in combustion? Under Render, I go to Video for Windows, and then to Options to choose the codec.
              Tim Nelson
              timnelson3d.com
                Oh I see, it is a separate install from the encoder, you need the Windows Media Video 9 VCM Codec. Then it will show up under the codec options.
                info
                http://www.microsoft.com/windows/win...q.aspx#VCM_2_1
                Download http://www.microsoft.com/windows/win...&qstechnology=
                Eric Boer
                Dev
                  I cannot for the life of me get that to work. I downloaded pretty much everything there is to download, played a file that was encoded with series 9, and still nothing. I don't know what the problem is. Eric, you're on Combustion 4?
                  Tim Nelson
                  timnelson3d.com
                    Yes, I'm using combustion 4, that link I gave you defaults to the Main windows media downloads, sorry didn't notice that.
                    Hopefully this link will work, have you already downloaded this file?
                    http://download.microsoft.com/downlo...v9VCMsetup.exe
                    Eric Boer
                    Dev
                      windows media uses direct show codecs
                      divx and others are video for windows (vfw) codecs
                      if only vfw codecs show up in combustion it could be that combustion is vfw only (virtual dub used to be vfw only, too and some codecs didnt show up there for the same reason)
                      an alternative would be to use the windows media encoder that comes with windows media 9 (its a standalone tool) on uncompressed avi files
                      the tools also gives you much more control over your compression results
                      there also are lossless compression codecs for use with vfw applications that have compression ratios of about 1:2
                      might allow you to save a little space before doing final compression with windows media
                      cu mike
                      lossless codecs:
                      worked for me:
                      http://forum.doom9.org/attachment.ph...2&d=1052847477
                      (it's a bit difficult to install, make sure to read the readme inside)
                      not tested:
                      http://www.alparysoft.com/products.php?id=8&item=35
                      http://www.compression.ru/video/ls-codec/index_en.html
                      http://www.codec-download.com/module...ore__PNG_0.8.2
                        Dude, I owe you big time! Looks like that one did the trick.
                        Tim Nelson
                        timnelson3d.com
                          Thanks Mike, I will check those out too.
                          Tim Nelson
                          timnelson3d.com
                            cool
                            Eric Boer
                            Dev
                            • #15
                              Keep in mind that the the DivX compression you do in Cleaner does NOT entitle you to distribute DivX endoded files commercially: you still need to buy a license for that use (NOT the DivX or DivX Pro encoder/program but a real commercial use license; just read the DivX EULA in one of your Cleaner folders or see the DivX website). So you better use WMV !!!
