DWG Link problem in Max 8
  • DWG Link problem in Max 8
    Hi
    I'll post this on the Max forum but thought I'd give it a go here first.
    I've just upgraded to Max 8 SP3 and I'm having problems with DWG Link. It's basically dropping materials and modifiers on reload.
    I think this is a known problem but was wondering if there is a workaround.
    It's actually ok if elements are just moved but if copied and/or new object/layers added to the DWG fails on reload (mats and modifiers)
    I've tried using different DWG versions, 2005 and 2002 but no luck.
    Anyone come up against this?
    It's so annoying for me as DWG link is key in my workflow, I'm pretty screwed without it.
    Cheers,
    Richard
    make sure you have *use scene material definitions and *use scene material assignments on Reload checked in the advanced tab of the file link manager
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      jacksc02
      I have them checked but no difference, does it work ok for you then?
      Thanks,
      Richard
        yeah no problems here, if you want send me part of your file and i can have a look for ya
        Chris Jackson
        Shiftmedia
          just sent you a pm with my email.
          Cheers,
            Think I've sussed it, I was creating the DWG as 2005.
            DWG Link seems to work correctly if created as v14 or lower.
            I'm not sure if this is a problem with my exporter (Microstation), probably is because if I edit the 2005 file as DWG (no export) it behaves correctly.
            At least I have a workaround for now.
            Richard
              weird, the link manager works fine for all autocad and archicad created DWG files. Like you said there must be something wrong with microstatioins DWG export
              Chris Jackson
              Shiftmedia
                It is odd, it works ok in Microstation's 'DWG workmode' (no translating, working directly on the DWG)
                I was told that there is a known problem with DWG Link in Max 8. Now I'm not sure what the problem is - from Max's side.
                I'm awaiting a response from support on this.
