Free Ocean Waves Sim
  • Free Ocean Waves Sim
    Hey everyone,
    just had been pointed to this by some friends. Looks pretty neat and is free. It´s tileable and based on the Tessendorf Paper.
    Maybe helps
    http://charles.hollemeersch.net/Projects/24/oceanwaves
    Regards,
    Thorsten
    Wooo hooo!!!
    Many thanks Thorsten!
    You can never have enough ocean shaders
    Rob.
    .:www.mcphersonyachtdesign.com:.
      Cool looking plugin. Thanks for the link. I wonder if it works with max9.
      Regards,
      Mike
      http://mikebracken.cgsociety.org/gallery/
        That looks damn cool.
        Pity its a max6 plugin tho
          wow very cool. Its not a shader though. Too bad its scale is not changeable.
            for the max9 peeps I wonder if an animated displacement map could be made and used.. wonder what render times will be like.
            Might give it a shot.
              Interesting idea daforce. I have had very little control over animated noise. But diplacement..........Hmmmm
              Regards,
              Mike
                Well tested it out and it works fairly well.
                Rendertime is alot higher for the displacement version, but that is just using default displacement. Im sure it could be possible to get lower rendertimes with better setup of the displacement.
                I was doing this all thru VNC so couldnt really be arsed testing it all too much
                With the displacement version I used the water level to cut of the flat edges around the waves, if you used a large area these parts would be off screen and not matter how they looked.
                Using the Plugin. 24s
                Using 3D Displacement, 1m44s
                Using 2D Displacement, 1m34s
                  ya I did some messing with it as well. The plugin object looks alot better with a smooth modifier on it. Turbosmooth just jack it up big time.
                    Yeah I noticed that as well, it looks very faceted. I imagine a smooth mod would help a fair bit too without adding to the poly count.
                      yeah it works well. completely screws your viewport performance though...
                        Yeah i imagine it would
                        I wonder if it will ever be re-written for max9, and maybe with more scale/tiling control.
                          wooohooo! i can't believe it! and it's free! and tileable! amazing! too good to be true!
                          instinct, you've made my day! hell, you've made my year!
                            ahh, ofcourse, too good to be true - it doesn't work with max 9?
                            • #15
                              As I said early.. no it doesnt. Hence my tests with displacement for using in max9
