clay tiles
  • clay tiles
    this is the structure im working on, not entirely sure what to do with the corners, i know i need tiles on the corners but should i just use strips comming down. also with the displacement method the tiles dont have thickness. im using a flat surface. how can i get thickness
    can someone upload a sample roof
    you need to run a half pipe along the ridge and hips
    http://www.albany-roofing.co.uk/roof-parts.htm
      #11 the valley was one thing i was wondering about
        Hey dude. To get thickness what you might need to do is fake it.
        Instead of using a tiled map like i imagine your doing. make one big texture map you can use to cover a whole side of the roof, then in PS have a couple pixel edge running alone the bottom that is abit darker, that will displace that part less and give the illusion of having thickness for the tiles
        However if seen from below you will see that there is none. But from side and top it will look good.
        You could go for a geometry option. A nice tile set has been posted in the general section.
          i ve never used it my self, but i ve seen recently an interesting aproach...keep ur current displaced planes but replace the last row tiles by geometry ones...same ways with the joints...though i d just skip the joint ones and use a displaced smaller plane for those joints...
          Nuno de Castro
          www.ene-digital.com
          nuno@ene-digital.com
          00351 917593145
            i decided to stick with the displacement method. i know my clients would never notice small details anyhow
              could you share the textures used?
              thx in advance!
                no textures, its procedural
                  so.. could you share the sader?
                  thx
                      thx a lot!!
                      a masterpiece!
                        that pool is looking awesome!
                        Nuno de Castro
                        www.ene-digital.com
                        00351 917593145
                          pool didnt take long at all to setup. pools have gotten to be second nature to me.
                            one can guess from that image...everything else is still sketchy but the pool!
                            Nuno de Castro
                            www.ene-digital.com
                            00351 917593145
