AdvanceNoise Material
  • AdvanceNoise Material
    Hi all, we have made a new noise material for max9x32 and x64 an would like to share it. If you like i can add new functions if i can find the formulas.
    Maybe i can make a project at sourceforge for this if have some time. Also if you find some bug just tell me.
    For now there are this functions: Cell, fBm, Perlin. Periodic, Turbulence.
    There is also a fractal option but it's not working very well. The base code is from the noise function from max, and the noise functions are based on cgtoolkit formulas.
    Daniel Santana
    [EDIT]
    Zip with all versions and vc runtime. Adds a new texmap and some bug fixing for maxscript access and bump mapping support.
    advnoise
    [17/07/2007]
    New texmap (MusgraveNoise) and bug fixing.
    [edit]
    There was a pretty stupid bug that didn't let the map slots work, but it's now solved, also we can now mix the colors of this slots with the color modes of voronoi. Didn't have time for max9x64 only monday, will there be an update.
    [29/04/2007]
    version 1.1.5 adds some new options to voronoi and show map on viewport. Also any files saved with the old version will lose the Output parameters.
    [30/04/2007]
    Added max9x64 plugin again. Also i setting up a page with some information about it at http://www.4arq.net/advnoise/advnoise.htm.
    Please use all this at your one risk i cannot be held responsible if anything goes really wrong.
    Daniel Santana | Co-Founder / Technical Director
    You can do it! VFX
    Lisbon/Porto - Portugal
    http://www.ycdivfx.com
    Thanks a lot...
    Best Regards...
    My Flickr
      ah man!
      Make it commercial!
      Max lacks good onises, and has been so from day 1...
      Cheers for now!
      Lele
        Error code 14001 on plugin load: the module failed to initialise.
        Max 9-32 bit, xp32 bit, vray rc3, greeble (nothing else installed).
        Geez i'm dying to test it...
        Lele
          Ok i know what it is. It's the vc runtime libs i will make a installer but it will take a while. I will post it really soon.
          P.S. Is there a way to force a compile with a specific vc runtime?
          Daniel
          You can do it! VFX
            OK i found that this is due to the new vc runtime in sp1 so here it's a quick fix to this and can't build against the vc of 3dsmax9.
            The VCRedist for x86 and x64, so we can get away with no installer, of course it's required to install in all render nodes.
            P.S. I'm working on a installer with support for network deployment and support for patches, probably in a .msi form.
            Daniel
            You can do it! VFX
              this looks very promising!
              thumbs up for the efort!
              obrigado!
              Nuno de Castro
              www.ene-digital.com
              nuno@ene-digital.com
              00351 917593145
                Hi again, in the first post there is now a link to the installers for both max9x32 and x64. If someone requires a build for max8 or max7 i can upload it too.
                Thanks for the replies. Any problem just say or if you found a cool function to use i will add in the future builds.
                Daniel
                You can do it! VFX
                  daniel could you put up a max 8 build please?
                  Chris Jackson
                  Shiftmedia
                  www.shiftmedia.sydney
                    oh, excellenet! great job!
                    finally someone took responsibility and made better noise
                    this has been wanted for ages, thank you so much santana!
                      That's a very good idea, thank you.
                      I'm waiting for max 9 to test it.
                      Bye
                      Gael
                        Ok thanks for all the comments. There is now online a max 8 build, the link is in the first post.
                        Daniel
                        You can do it! VFX
                          Nice Job so far! I'd vouch for a Voronoi/Worley implementation Very flexible
                          Regards,
                          Thorsten
                            Hi instinct,
                            Voronoi was on the plans, i studying the implementation in Blender so let's see what i can come up without make a UI confusion but letting control everything.
                            Daniel
                            You can do it! VFX
                            • #15
                              Ok Voronoi is now available. It's a implementation of Blender Voronoi texture.
                              Happy weekend,
                              Daniel
                              You can do it! VFX
