vista or xp????
  • vista or xp????
    Hi all,
    just got new laptop with vista, now question, would you directly switch to xp, or leave and run with vista???
    any opinions?
    best regards
    Jonas
    Jonas
    www.jonas-balzer.de
    www.shack.de
    Xp all the way.
    I am taking vista off my new Dell laptop because it is so bloated and memory hungry.
    On my render nodes that have 2gb they get by just fine rendering my images. The dell with vista installed just chokes and say that it has run out of memory even before it starts rendering.
    I hate vista now, I really gave it a chance, but I am done with it. Its just not pretty enough to put up with the stress.
    XP64 is the best choice.
      2nd xp64.
      WerT
      www.dvstudios.com.au
        XP
          64 or 32 bit version of Vista ? More than 8 gigs ram?
          http://mikebracken.cgsociety.org/gallery/
            Hi Jonas...
            did they finaly give it to you ?
            sorry i cant use msn anymore to chat with you...
            maybe ill get it back later.
            lass mal mittags an der Strandperle mittachen...
            Tom
              My GF's new lappy has Vista on it. I might end up taking it off if it becomes a problem. Just not sure if the drivers will be available for it.
                i think i'll gave vista a little chance cause haven't any money anymore for xp at the moment. max only starts by right click icon and say "start with admin rights". but i'am admin.......... when i dubble click an error occurs...
                Jonas
                www.jonas-balzer.de
                www.shack.de
                  From memory, I think I had to turn off something called User Account Control to get Max to work on Vista.
                  It warns you that what you're doing is a bad idea and that the polar ice caps will melt if you continue but it makes Max work.
                  Dan
                  Dan Brew
                    Using 3dsmax 9 with sp2 or extension 1rev3, helps. We had no need to set the "run as administrator". 3dsmax8 requires the "run as administrator" (set in the properties) or disabling the uac.
                    But after everything is running there are some problems in the file dialog, clicking in a file when saving and then change the name doesn't seem to work and he always assume the file we clicked (better try since my explanation isn't that good). Also when using the asset tracking and setting the paths we must add an extra "\" in the file dialog or max sets the path to the directory just one level below. I think max is only going to work perfectly with vista in max 10 (or may not).
                    Daniel
                    Daniel Santana | Co-Founder / Technical Director
                    You can do it! VFX
                    Lisbon/Porto - Portugal
                    http://www.ycdivfx.com
                      WTF............... vista s....... 2 days i'am try'n to install max now. seems that the prod. booster dond't like vista, or other way round. always i install i get error.. to be continou'd......
                      Jonas
                      www.jonas-balzer.de
                      www.shack.de
                        Uninstall Vista...
                        Smash the disk in with a hammer...
                        Install xp64...
                        Enjoy greater karma.
                          i will..........
                          Jonas
                          www.jonas-balzer.de
                          www.shack.de
                            Do you want DirectX 10 ? if no, install XP or XP64
                            The Vista sp1 is in beta test, wait and see
                            In teapots we trust.
                            • #15
                              hmm, argument! 1:0
                              max with sp2 runs now...
                              Jonas
                              www.jonas-balzer.de
                              www.shack.de
