We are doing some camera matching type work in Max where we need to make fine adjustments to the position of a camera to allow the building (10 miles or so away from the camera) to go into the correct location.
The max scene is in meters.
We need to make fine adjustments to the camera position - 10 mm increments or so - in its position. The problem is, because we are so far away from the origin (even when working in meters), the camera does not move by the fine increments that we input. If we move it close to the origin, it works just fine.
This must be a common issue with accurate camera matching.
Any tips or suggestions (apart from converting the scene to km and working with stupidly small numbers)?
