I know there are probably some threads about this , but i can't read through all of them!
So, I have this problem with DR, but it's only maps that are a problem.
I have on machine and one slave, xp 32 and xp x64 (main)...
Vray 1.5 DR works great, but if there are textures, the slave can't see them during DR! I can fully control/access/modify all the files through the network in both directions, so I'm feeling like there are no security/firewall/permissions issues, etc.
If, I use LeLe's stuff collector and put all the maps locally on the slave, than the problem goes away and DR renders fine.
So the point of this is to see why this is going on? I want the maps on the main computer in case I want to work on it with the slave not running, for example.
So, is there any way to make this work? it's really frustrating.
Thanks,
JR
edit: Actually, even after the slave can get the maps, the slave's buckets come out as different tone/lightness!? Maybe this is a lic. prob or VRay problem?
(see the flooring for problem buckets)
Thanks,
JR
