Welding vertices in max 9
  • Welding vertices in max 9
    Hi there,
    Does anyone know why I cannot weld some vertices in max 9. I have units at mm's and have overcome this problem before by creating a brand new spline and then attaching the problematic one..but this wont even work.
    Any ideas ??
    Cheers
    Steve
    Regards
    Steve
    My Portfolio
    Mesh:
    Double faces, edges
    Spline:
    extra segments
    Eric Boer
    Dev
      If your object is an editable poly object, some reasons for not being able to weld are:
      double faces/edges/
      or your vertices do not share an edge
      (#s are Vertices), this ascii art illustrates 2 tris/1 quad, dashes are edges
      Code:
      1-------2
      3-------4
      Vertices 1 and 4 will not weld because they do not share a common edge, neither will 2 and 3
      Colin Senner
        Re: Welding vertices in max 9
        just to clarify... you did say spline right?
        Originally posted by steveiouk
        Hi there,
        Any ideas ??
        Cheers
        Steve
