Crysis
  • #91
    No, didn't get around to doing any trees or anything, did add a tornado though :P
    Next I think I'll try rendering a height map of the hi-res mesh so I can use the standard terrain and the road tool on it. the editor supports up to a 8k height map not sure how to import one yet though..
    Eric Boer
    Dev
    • #92
      How are you guys running the demo? I got it to work on my laptop with an ATI card, but it crashes my desktop machine with an NVidia 8800 on the initial credits Maybe I need newer drivers or something... or 32-bit Windows (I'm on 64-bit right now)?
      • #93
        daforce: the driver cleaner worked tnx
        • #94
          Vlado:
          64bit should be fine. I have seen a few people playing on 64bit without problems.
          Its most likely due to old drivers. Download the latest betas from nvidia 169.04 I believe, and install those. Ideally using my instructions above about driver cleaner.
          aphex79:
          Excellent
          • #95
            Aaaaaah, we DID it!
            We managed to get him close to hooked
            I am playing it on a 8800 gts 640mb, latest RELEASE (not the optimised, beta) drivers, under xp pro 64.
            Ah, and also "only" (goddamn it, it makes it seem a cpu of the past XD) on a x2 4200.
            Go for it Vlado! (interested eyes looking over your shoulder, here...)
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
            • #96
              In Vista 64, the 32 bit version worked for me straight away to run 64 bit I needed to go into the nvidia control panel and turn "vertical sync" to "force off" and "Multi-display/..." to "single display perf mode".
              Eric Boer
              Dev
              • #97
                i used the editor to change the turtle at the start of the game to a hind chopper muahahahahah that thing pwns :P
                WerT
                www.dvstudios.com.au
                • #98
                  guys do you think that the demo would run with a fire gl 7300 video card ?
                  it's a dual opteron 270 with 4gigs of ram
                  • #99
                    only one way to try
                    Lele
                    Disclaimer:
                    • vlado
                      Try running 32-bit executables. Under vista I had a problem with 64-bit version not running at all. It locks right after the startup videos. Somehow I got it runnin in windowed mode (you can switch to fullscreen in game menu). Of course vista is x64... Maybe newer drivers does make sense, but for me they are slower. A bit slower.
                      I just can't seem to trust myself
                      So what chance does that leave, for anyone else?
                      CG Artist
                      • Well I tried both 32- and 64-bit... both freeze my machine, but the 32-bit version at least managed to show some of the initial credits... anyways, I will update the drivers and see what happens.
                        • im running the 64bit versions with no problems.
                          Got the 32bit version running on a macprowith an ATI card with no problems either
                          Chris Jackson
                          Shiftmedia
                          www.shiftmedia.sydney
                          • i have no issues running the game. But when in play, if I look at the sky, then look down onto the terrain, i get a ghost image imprinted from the sky, that kind of jumps around the screen for a bit then goes away..
                            Dmitry Vinnik
                            Silhouette Images Inc.
                            ShowReel:
                            • Originally posted by vlado
                              see my last post...
                              Eric Boer
                              Dev
                              • Originally posted by Morbid Angel
                                strange, i had same issue when i went out last morning after a long drunken night.
                                Jonas
                                www.jonas-balzer.de
                                www.shack.de
