Material editor VrayMtl defaults,
  • Material editor VrayMtl defaults,
    Hi there people,
    i was trying to get somewthing to work. for example if i load max all materials would be default to VrayMtl. i got that working by replacing the medit.mat file.
    Second i want to have the default type material set to a vrayMtl. if you check the currentdefault.ini file of 3dsmax you'll see the section :
    ; Material Editor
    ; materialType
    ; Standard Material = 2 0
    ; Architectural Material = 0x13d11bbe 0x691e3037
    ; Raytrace Material = 0x27190ff4 0x329b106e
    [100 C80 0]
    ; Standard Material
    materialType= 2 0
    So i thought, i'll get the classid of a vrayMtl and set this to the default...
    VrayMtl.Classid
    #(935280431, 1882483036)
    That is not working. so i checked the classid of a standard material #(2,0) wich is the same as the ini file. but when i check class id of a architecturalmtl it different.
    Architectural.classid
    #(332471230, 1763586103)
    So perhaps any1 has an idea what that values should be ?
    My Homepage : http://www.pixelstudio.nl
    those numbers are in hex, try : 0x37BF3F2F 0x7034695C
    http://www.easycalculation.com/decimal-converter.php
    Eric Boer
    Dev
      hmm yeah i think you are right about that, should have thought of that myself
      but well it's not seem to work, or al least does not what i want
      I changed the number, save ini, started max
      Now i get my defaul material loaded from my medit.mat file (all vray)
      But if i for example create a multi-mat material it gets filled with standard materials.
      if i condense materials i also get standard materials.
      now i'm not sure changing this should affect things states above but well.
        The Multi/Sub material explicitly creates only Standard materials (this is hard-coded into it).
