Array
  • Array
    I have a non-v-ray question. If I have a fence that I would like to follow a path, how would I go about it? I saw a script over on itoo, but I couldn't get it to work. The fence consists of a post and panel that I want to repeat.
    http://www.itoosoft.com/english/menu.php?id=clone
    Thanks,
    Bob
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Path Deform
    Got it. I used the clone plugin with path deform. I answer my own questions a lot, but hopefully someone else can find this helpful.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      You can use "Spacing Tool", which does just that. It's located where Snapshot, arrray etc ... are.
      Zoran
        Yeah,
        We've probably used clone on almost every project since we discovered it. Its nice having it in the modifier stack so you can change everything on the fly.
        Derik Bibb
        Architectural Visualizer
        TANGRAM 3DS
        International 3D & Design Solutions
          I've used spacing tool, but I prefer animating a baluster with a path constraint, then snapshotting it to create all the balusters.
          "Why can't I build a dirigible with my mind?"
            We use spacing tool here, it has all the right options to fit pretty much any fence situation.
            Ben Steinert
            pb2ae.com
              i must be missing something here. Why wouldn't you use the fence ae tool in max that follows any path you have? If the panel is the problem, why wouldn't you just make one of the verticals the same dimension as the panel?
              mh
