Anyone got new GeForce GTX 280 1GB GDDR3? Any 3dsmax viewport performance boost?
GeForce GTX 280 1GB GDDR3 any performace boost?
Tags: None
dont know about that one, but I recently got geforce 9600 gt overclocked 512 mb and its waaay better then 8800 gtx in both maya and max. And it costs 200 bucks.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
Originally posted by Morbid Angel View Postdont know about that one, but I recently got geforce 9600 gt overclocked 512 mb and its waaay better then 8800 gtx in both maya and max. And it costs 200 bucks.
I'm thinking to do 3way SLI with the gforce 9600gt (XFX overclocked: GPU Clock: 700 MHz, Shader Clock: 1750 MHz, Memory Clock: 2000 MHz) + mobo evga 780i.
http://www.evga.com/articles/385.asp
http://www.guru3d.com/article/nvidia...i-review--xfx/
But I didn't find info about how much power(watts) it will need.www.thefakeworld.net is back!
Last I heard, Max won't take advantage of an SLI configuration. Correct me if I'm wrong though.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
yep! if max took advantage of SLI i would got that route loooooong time ago.
But it doesn't so we need one powerful cardLuke Szeflinski
:: www.lukx.com cgi
i had a x2900 ati card
then got a 8800 and spewed at the performance drop
so went and got a 3870 ati card instead and back to happy levels of speedWerT
www.dvstudios.com.au
4850 and 4870 ati's are out now and have killer performance for little $WerT
so ATI Radeonâ„¢ HD 4870 X2 or EVGA Geforce 280 FTW ?
I'm long nvidia user and I'm afraid to switch to ATI. I somehow don't trust them I don't know why.Luke Szeflinski
:: www.lukx.com cgi
i have a nvidia 8800 softmodded to a quadro 4600 and its really fast in direct 3d.
i cant install maxtreme drivers for some reason but i dont think they are really necessary.
i would like to compare it to one of the newer cards like the 280 but i dont know how to benchmark this in max.
can you still softmod those newer cards?Reflect, repent and reboot.
Order shall return.
Originally posted by dlparisi View PostLast I heard, Max won't take advantage of an SLI configuration. Correct me if I'm wrong though.
Is there any scene benckmark to test graphic cards? I have a gtx280 now and I see a huge difference from my old one (geforce 7600).www.thefakeworld.net is back!
Originally posted by lukx View Postyep! if max took advantage of SLI i would got that route loooooong time ago.
But it doesn't so we need one powerful cardI haven't heard a definite answer that 3d studio supports any SLI (or Xfire) implementation. And I've also never seen a definitive answer that answers whether or not a dual chip card (i.e., any "x2") is seen by the application as a sli setup (since it's using two GPU's) or as a single card (well, since it's a single card). Basically, I'm asking if for applications that may not use SLI (i.e., Max not games) if there's any advantage for an "x2" card. If the answer is "no" then you'd be best off dropping down to the standard HD4870 at half the cost for the same performance. Any one know answers to the above? I'd like to know as I'm contemplating an upgrade some time soon as well.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Not sure about SLI - but I did see a boost between a 8800GTX and the 260 model.
Bought that babe yesterday280 GTX MSI OC (@650)
I don't know, if it is faster in viewports, but damn... Crysis totaly rocks!!!
If you need me to test smth - let me know.I just can't seem to trust myself
So what chance does that leave, for anyone else?
CG Artist
Originally posted by Paul Oblomov View PostBought that babe yesterday280 GTX MSI OC (@650)
If you need me to test smth - let me know.Dmitry Vinnik
ShowReel:
I have an 8800 GTX 768MB @ home and I have a 280 OC BFG 1GB card at work that replaced a Quadro 4500.
For normal day to day work, with scenes in the 1 million poly range, there is very little difference between the 8800 and the 280. The quadro 4500 with MAXtreme is noticeably slower. Not by a lot, but enough to make me notice the speed difference. Once the scenes start getting larger the 280 really starts to pull away. Neither card does well with lots of spline data in Max unfortunately. Anyways, for the price, I am very happy with the 280.
Performance tests done in Max 9 & Max 2009 (view cube disabled).
