Helping a hopeless maxscripting guy
  • #16
    Originally posted by mmrender View Post
    Hi Jrandom, I try the first piece of code that you sent, following your instructions and it is working for me perfectly. I was applying it to a cilinders with no problem. Only, I would need to apply to several objects at the same time, could you help me on that? I suposse it is a matter of add a line in the code but I'm very poor with this issue. Many thanks, you make my day.
    Code:
    try(destroyDialog AlignBboxToObject)Catch()
    --arrays
    Obj_arr = #()
    list_arr = #()
    --functions
    fn AlignBBoxToFirstNormalfn1 theObject = --Function written by Borislav Petrov
              theCurrentTM = theObject.transform --this is the current transformation
              theMesh = snapshotasmesh theObject --get the world space TriMesh
              theTM = matrixFromNormal (getFaceNormal theMesh 1) --build a matrix from normal
              delete theMesh --delete the TriMesh from memory
               theTM.row4 = theCurrentTM.row4 --set the position of the new matrix to the old pos
              theObject.transform *= inverse theTM --transform out of world space
              resetXForm theObject --reset the XForm
              convertToMesh theObject --collapse the stack
              theObject.transform = theTM --transform back into world space
     fn AlignBBoxToFirstNormalfn2 theObject = --Function written by Borislav Petrov
             theZ = normalize (getFaceNormal theMesh 1)
             theFace = getFace theMesh 1
             theY = normalize ((getVert theMesh theFace.y)-(getVert theMesh theFace.x))
             theX = normalize (cross theY theZ)
             theTM = matrix3 theX theY theZ theCurrentTM.row4
    fn Obj_filt obj = isKindOf obj GeometryClass
    fn objList =
            list_arr = for o in Obj_arr where isValidNode (obj = getNodeByName o) collect obj
    --rollouts
    rollout AlignBboxToObject "Align Bounding Box" width:200 height:200
        button btn_Load "load"
        ListBox lst_objs
        button btn_doFn1 "Function 1" across:2
        button btn_doFn2 "Function 2"
        on btn_Load pressed do
                Obj_arr = #()
                SelObj = selectByName title:"List Objects" filter:Obj_filt()
                if SelObj != undefined do
                        for i in SelObj do
                                append Obj_arr i.name
                                objList()
                if Obj_arr.count != 0 then
                    lst_objs.items = Obj_arr
        on btn_doFn1 pressed do
                deselect
                for o in list_arr do
                    AlignBBoxToFirstNormalfn1 o
        on btn_doFn2 pressed do
                deselect
                    AlignBBoxToFirstNormalfn2 o
        on AlignBboxToObject closed do
                Obj_arr = #()
                list_arr = #()
    CreateDialog  AlignBboxToObject  width:200 height:200
    Both functions are included. So if one doesn't work use the other.
    particle makes perfect
    • #17
      Thank you man!! I test it in my scene with cylinders and the Function 2 works perfect.
      Once again the people of this forum is amazing! I hope to be able to help back someday.
      Manuel
