3dsmax.exe process running after 2010 exit
  • 3dsmax.exe process running after 2010 exit
    Anyone else notice 3ds Max 2010 leaving 3dsmax.exe processes running after you quit? I haven't put my finger on the exact cause of it - but several times have noticed I'd have 5 or so 3dsmax.exe processes going at the end of the day (none doing anything, just using up 200MB of RAM)...
    We're using V-Ray and a couple free plugs - greeble, dem2max, colorcorrect and bercon maps. I'm going to start removing the freebies one at a time to try and figure out what is causing this - in the meantime I thought I'd get the discussion moving in case we're not the only ones seeing this...
    Christopher Grant
    Director of Visualization, HMC Architects
    Portfolio, ChristopherGrant.com
    There was a similar issue in some of the beta versions of 3ds Max 2010, but I have not seen it with the final so far.
      I think it has something to do with Vista and user permissions.
      If you run a session as administrator it should exit properly. If you configure the properties of your shortcuts to run as administrator it will exit properly. If you open a max file through windows explorer the program will reside in memory upon exit. I have yet to find a way to always run max as administrator.
      Ben Steinert
      pb2ae.com
        No Vista here - we're all XP 32/64 although the only machines I've noticed the multiple process issue on are XP 64. I'll check into the XP 32 ones too...
        Christopher Grant
          Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090 X2
          • ​Windows 11 Pro
            Roger Roger this is Quick Reply, Over.
            I'm having the same issue. Latest hotfix, Win XP 64bit.
              Vista 64
              me too and I am running Vista 64 with MAX 2010 Design
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                FYI - I *think* the process is related to the ColorCorrect plugin. From my tests it seems like accessing the CC map causes 3dsmax.exe to get stuck in the task manager after exit.
                I've reported the bug at Cuneyt's forum for CC.
                http://www.cuneytozdas.com/forum/topic.asp?TOPIC_ID=645
                Christopher Grant
                  FYI - for anyone who finds this thread via search.
                  The problem of 3dsmax.exe processes not terminating has been solved by James Haywood by adding some maxscript code that utilizes dot net for forcibly terminate max on exit. It's been working perfectly for us for several days now. Actually it has the added benefit of making max exit after large projects instantly instead of taking quite a while to unload.
                  Read more at James' CGS thread here: http://forums.cgsociety.org/showthre...?f=98&t=850661
                  Christopher Grant
                    That's awesome this works perfect. Many Thanks !!!!
                    Ruben Gil
                    www.spvisionz.com
                    www.linkedin.com/in/s2vgroup
                      Thanks - this one has been driving me nuts.
                      b
                      Brett Simms
                      www.heavyartillery.com
                      e: brett@heavyartillery.com
                        Driving me nuts to!!!
                        And those lingering exes interfere with other programs (causing dialog boxes to hang and whatnot).
