how to create wicker/willow style lettering ?
  • how to create wicker/willow style lettering ?
    Hi guys,
    Ive been racking my brain/skill to try and come up with a way to model wicker that wraps itself around lettering and shapes. I have looked up scripts but cannot find anything. Does anyone have any methods or scripts or advice on how to accomplish this ?
    I have attached an image to show you the type of result I want.
    Regards
    Steve
    My Portfolio
    Pf spliner will make you lines from the part of particles travelling over the surface of an object.
    http://www.orbaz.com/forum/viewtopic.php?t=2279 - you'll need pflow box #1!
      Cheers Jo. I think I already have that script but dont have toolbox 1 for PF...maybe I need to invest..
      Regards
      Steve
      My Portfolio
        Wasn't Toolbox 1 part of a subscription extension in the past and now integrated in Max ? Could be wrong since I'm not a particle guy.
          I have max 2009, and I cant see it...maybe I need to upgrade..
          Regards
          Steve
          My Portfolio
            Should be in there alright - box #1 definitely got added in recently. Yep - into productivity pack 1 according to turbosquid - http://www.turbosquid.com/FullPrevie....cfm/ID/235453
              Jesus, didnt even know about that...coolio !
              Regards
              Steve
              My Portfolio
                Well, it kind of works ok, but there is no real uniformity of the particle paths. I dont really know how to control the particles so that they look like they are uniform weave rather than random shapes...
                Regards
                Steve
                My Portfolio
                  Maybe try driving the direction of the Particles with a wind so that you can push them a certain way along the contours of the model?
                    Yeah, I think Im going to have to experiment a bit with the wind. Ta
                    Regards
                    Steve
                    My Portfolio
                      If you got modo you could try to do it in there using curves and this technique: http://forums.luxology.com/discussio...86&show=curves
                      www.short-cuts.de
                        ...or try "SlideKnit" from the SlideLondon's site: http://slidelondon.com/iv
                        "This tool can help you lay things out on the surface of complex objects which have been UV-mapped. For example, you could craft an intricately-detailed knit-pattern mesh in a flat plane, then wrap this around a sweater-shaped mesh."
                        regards
                        steve blake - animator - designer
                        www.stevenblakedesign.co.uk
