Sketch render in Vray
  • Sketch render in Vray
    Hi all,
    I am actually making some render test (realistic, wooden model...) and I want to know if it is possible to have this kind of render in Vray with VrayToon :
    Source from cgarchitect: http://www.cgarchitect.com/news/Reviews/Review037_1.asp
    Other exemple made with ArchiCad:
    Thx.
    Zahir3d
    PIXARCHI.COM
    Second image is quite do-able with Vray Toon, but I don't think you can have extended lines like the first image.
      I've done images like the first one using vray toon, but you need to render out seperate passes and do a lot of photoshop.
      Nothing will do it automatically though, you're going to be using PS a lot whatever you render with.
        I hope to find a way to have the extended lines in MAX like the first image.
        Zahir3d
        PIXARCHI.COM
          maybe final toon can do that. just a guess though, never used it.
            Salut roya
            To obtain this, I put a VrayMtlWrapper with MatteShadows on OverrideMtl of the scene.
            Then you adjust the vray toon. The background have to be white.
            Appelles en cas
              Yes but what for the extended lines
              I want also to have some hatch on the dark area.
              Zahir3d
              PIXARCHI.COM
                Toon
                http://jg3d.blogspot.com/2009/09/ill...-max-2010.html
                Bobby Parker
                www.bobby-parker.com
                e-mail: info@bobby-parker.com
                phone: 2188206812
                My current hardware setup:
                • Ryzen 9 5900x CPU
                • 128gb Vengeance RGB Pro RAM
                • NVIDIA GeForce RTX 4090 X2
                • ​Windows 11 Pro
                  This one has some nice jitter and shading tools:
                  http://www.psoft.co.jp/en/product/pencil/
                  I will say though that if you spend enough time playing with the shaders in max and VRayToon, you can get some decent results.
                  I don't think you will find much for Max that will give nice extension lines. You could take your model into SketchUp or C4D Sketch & Toon and get some nice tools for extension lines...in fact I think your reference image was generated using C4D Sketch & Toon.
                  Ben Steinert
                  pb2ae.com
                    Tks all for this links!
                    Zahir3d
                    PIXARCHI.COM
                      I just drew my extension lines on in ps - doesnt take long and you can match the thickness of the vray toon easily.
                        Same here. It's much faster to do it in PS and you can put lines where you want them, not where software decides to do. It's actually suprising how small number of "extedned" lines is needed to achieve a "fuzzy-furry" effect
                        zoran
