3ds max 2010 design crashes on file open
  • 3ds max 2010 design crashes on file open
    So I got this strange problem. I have these scenes which work fine under windows xp 32 bit and max 2010 design x32 bit.
    Once I try to open them under windows 7 64 bit max 2010 design sp1 x64 it just simply crashes.
    Any idea why this happens? If I open those scenes under winxp again they are fine...
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
    For shits and giggles, have you tried opening the file through Max 32bit in Windows 7?
      yeah in winxp it opens fine. Its totally weird. It does have a plugin missing (treestorm) could that be the cause?
      sorry misread your post. It does not open in max under win7.
      Dmitry Vinnik
      ShowReel:
        Really odd. Does merging crash it too?
          i have not tried. I have read on autodesk forum that there is some sort of compression option that max is using when it saves the files and that could be the cause. I will try today and see if that works. I can see compression being an issue between 32 bit and 64 bit...but if I save the files under win7 64 bit, I cant open them on another machine with similar specs.
          Dmitry Vinnik
          ShowReel:
            I've never had any issues with the Max file compression between 32bit and 64bit. Then again I haven't tried opening files between XP and 7 yet. About the only issue I've seen is uncollapsed booleans created in 32bit Max causing issues in 64bit.
              have you tried "merge"?
              show me the money!!
