Annoying Real-World Map scale - how to set it OFF by default ?
  • Annoying Real-World Map scale - how to set it OFF by default ?
    I switched recently to Max Design 2010 from Max 7 and I'm constantly annoyed by the Real-World map scale always ticked on byu default. Does anybody knows how to switch it off by default ?
    Philippe Steels
    Pixelab - Blog - Flickr
    Where are you seeing this behavior? I am using Max Design 2010 and it is as always, unticked by default.
      When I create an object (box plane, whatever): Generate mapping coords + Real-World
      When I create a map (bitmap or procedural)
      When I add an UVW mapping modifier
      Always on by default...
      Thanks for your message, my hope of a solution is now renewed
      Philippe Steels
        look in the 3dsmax.ini if i remember correctly. There should be a line in there for that.
          try a 3dsmax design default sheme
          max 9 + vray
            under preferences there is an option to turn it off
            show me the money!!
              Exact Preferences / general tab / texture coordinates
              I feel like stupid, but searching the preferences always give me an headache !
              thanks all
              Philippe Steels
