Is there a way to add a noise modifier to something while keeping the border un-touched? I have a site, with grass, that I would like to add noise to it, but I want the edge along the curb to be left alone.
noise
noise
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
perfect, thanks!Bobby Parker
phone: 2188206812
- Windows 11 Pro
OK. I was able to select the open edges, use the softselect, but I actually want the reversed selection.Bobby Parker
phone: 2188206812
- Windows 11 Pro
great, thanks!Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by percydaman View Postclick edit-invert selection.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Try the Volume Select mod. Far and away the most versatile selection tool. You can make a selection of verts using a box volume gizmo and set the falloff from there.
One of the best things about Vol.Select is that it does not use a specific array of vert or face numbers. So if the topology changes below the VolSelect mod, you still have consistent results.
