How do I replace texture maps (not relink)?
  • How do I replace texture maps (not relink)?
    This has always been a huge annoyance for me in max. Doesn't happen often but every now and then I want to replace a texture used in a file (maybe in many different materials which might not be instanced).
    I might want to use a lower-res version or a newer version of the file or whatever. The trick is the replacement file has a different name, so I basically want to do Find/Replace for the texture that's used in the file. Seems this should be a no-brainer built into the Asset Manager but I don't see such a function.
    Can anyone help?
    use the asset tracking dialog instead, right click on the texture and select browse. you can then select what ever texture and it will be replaced
      I've done it by having two sets of master files in different named folders - files have same names
      then I copy in high or lo res version to the directory referenced by the material editor, as needed
        Thanks Jay. I knew there had to be a way. I think I even did this once but forgot about it.
