Smooth
  • Smooth
    Hello-
    Here is something that causes me problems, but I just usually deal with it. When I pick the edge of a poly, hold the ctrl down to drag a copy, the poly gets this smooth modifier or something applied to it. I deal with it by detaching the new polygones. Once I detach the smooth modifier seems to go away. It is almost like the automatic smooth modifier that is applied to a loft.
    Any way around this?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Do you have an image to illustrate this? It sounds like a smoothing group issue.
    Troy Buckley | Technical Art Director
    Midwest Studios
      Here is a 30 second screen grab
      http://www.screencast.com/t/YTg0OTQ3ZD
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        try working in editable poly. Haven't seen this before.
        Two heads are better than one ...
        ....but some head is better than none.....
          use Edit Poly, edit mesh is the problem. Edit poly is way better to work with too.
            Yep...that is just a smoothing group problem. If you are going to start modeling in that fashion. Follow these steps and all should be fine. I just tested inside of Max2011 with editable mesh/poly with the same results.
            Create Rectangle
            Convert to Editable Mesh/Poly (Doesn't matter which, this works for both)
            Go to Poly mode, select all Polys
            Under the Surface Properties Rollout -> Smoothing Group Subsection -> Click the "Clear All" button
            You can now edge extrude with no smoothing group problems.
            Midwest Studios
              Thanks Donald and guys.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
